Programmatically installing a plugin
here is some code that you can add to your plugin if it relies on another plugin being installed to work
for this example I am going to use the Broadcaster plugin. you can use either the plugin's GUID or the name of the plugin will also work. but this will use the class name to check and see if the plugin is installed
BROADCASTER_GUID = "{5E8DA56B-24AC-4092-9521-169343C5171C}"
BROADCASTER_CLASS_NAME = "BroadcastListener"
def InstallPlugin(plugInfo):
    eg.AsTasklet(eg.UndoHandler.NewPlugin(eg.document).Do)(plugInfo)
if not hasattr(eg.plugins, BROADCASTER_CLASS_NAME):
    pluginInfo = eg.pluginManager.GetPluginInfo(BROADCASTER_GUID)
    wx.CallAfter(InstallPlugin, pluginInfo)
Re: Programmatically installing a plugin
and here is some code if you wanted to set the plugins startup parameters programmatically. if and only if the plugins default parameters will not throw a traceback. this closes the plugins config dialog and then sets the new parameters.
the only way to do this if it does throw a traceback is to use dialog.panel.GetChildren() and set the values for each of the specific widgets then call wx.CallAfter(dialog.DispatchEvent, None, wx.ID_OK) this will set the values then close the dialog.. and you can then remove the wx.CallAfter(treeItem.SetArguments, STARTUP_PARAMETERS)
import wx
import threading
BROADCASTER_NAME = "Broadcaster"
STARTUP_PARAMETERS = ("TestBroadcaster", "255.255.255.255", 33333, False, "&&", "")
EVENT = threading.Event()
    eg.UndoHandler.NewPlugin(eg.document).Do(plugInfo)
    EVENT.set()
def CloseDialog():
    while not EVENT.isSet():
        if eg.document.frame.openDialogs:
            dialog = eg.document.frame.openDialogs[-1]
            if hasattr(dialog.treeItem, 'info') and dialog.treeItem.info.guid == BROADCASTER_GUID:
                EVENT.set()
                treeItem = dialog.treeItem
    wx.CallAfter(eg.AsTasklet(InstallPlugin), pluginInfo)
    threading.Thread(target=CloseDialog).start()
and here is an example of setting the parameters at the widget level
import wx
import threading
STARTUP_PARAMETERS = ("TestBroadcaster", "255.255.255.255", 0, 33333, False, "&&")
    EVENT.set()
def CloseDialog():
                try:
                    children = dialog.panel.GetChildren()
                    if len(children) < 6:
                        continue
                except:
                    continue
                prefixCtrl, zoneCtrl, portCtrl, addrCtrl, selfbroadCtrl, _ = children
                prefixCtrl.SetValue("TestBroadcaster")
                zoneCtrl.SetValue("255.255.255.255")
                portCtrl.SetValue(12345)
                addrCtrl.SetValue(0)
                selfbroadCtrl.SetValue(True)
                EVENT.wait()
