Fading Dialogs
Fading Dialogs
Here is a little tidbit of code for adding some "flare" to EG
create a macro with the event Main.OnInit
add the Python Script action and paste the code below into it.
then restart EG.. and open a config dialog for an action or a plugin.
import time
import wx
import threading
def Show(self):
    def run():
        transparent = 0
        while transparent < 255:
            transparent += 1
            wx.CallAfter(self.SetTransparent, transparent)
            wx.CallAfter(wx.Dialog.Show, self)
            time.sleep(0.005)
    self.SetTransparent(0)
    wx.Dialog.Show(self)
    threading.Thread(target=run).start()
eg.globals.original_destroy = eg.ConfigDialog.Destroy
def Destroy(self):
    def run():
        transparent = 255
        while transparent > 0:
            transparent -= 1
            time.sleep(0.005)
        eg.globals.original_destroy(self)
eg.ConfigDialog.Show = Show
eg.ConfigDialog.Destroy = Destroy
Diz
Re: Fading Dialogs
Post by Diz »
thats pretty awesome! by the way the indents are back when you use the 'SELECT ALL' button :(
Re: Fading Dialogs
hmmmm don't know why... I am messing with it now but it appears as tho it got reverted.. and I am not sure as to why
