If you find this forum valuable and would like to help keep it online, donations to help cover hosting and domain costs are greatly appreciated, but never expected. You can support the forum through
Buy Me a Coffee or
Ko-fi . Thank you for helping preserve the EventGhost community.
yokel22
Posts: 265 Joined: Thu Feb 05, 2015 5:56 pm
Post
by yokel22 » Sun Feb 04, 2018 7:31 pm
Anything pre rc4 should work.
I haven't used pycurl before but this may work in rc4+ versions. Worth a shot.
import pycurl
from StringIO import StringIO
key = ' '
baseUrl = 'https://home.sensibo.com/api/v2'
cmd = '/users/me/pods'
buffer = StringIO()
c = pycurl.Curl()
c.setopt(c.URL, baseUrl + cmd + '?' + 'apiKey=' + key + '&fields=id,room')
c.setopt(c.WRITEDATA, buffer)
c.perform()
c.close()
body = buffer.getvalue()
print(body)
Mastiff
Posts: 872 Joined: Thu May 03, 2012 10:43 am
Post
by Mastiff » Sun Feb 04, 2018 8:50 pm
Seems like there's less and less error lines. Is that a good sign?
21:49:36 Traceback (most recent call last):
21:49:36 Python script "214", line 11, in <module>
21:49:36 c.perform()
21:49:36 error: (60, 'SSL certificate problem: unable to get local issuer certificate')
yokel22
Post
by yokel22 » Sun Feb 04, 2018 8:53 pm
That looks like the same kind of error. It's having problems finding the ssl certs on windows. Try the first one on pre rc4 if you can
Mastiff
Post
by Mastiff » Sun Feb 04, 2018 8:55 pm
Here's the output of the 0.4 version (which seems to work):
21:54:11 {u'status': u'success', u'result': [{u'id': u'oohZomrQ', u'room': {u'name': u'Varmepumpe ovenp\xe5', u'icon': u'bedroom'}}]}
In unicode it should be "Varmepumpe ovenpå", but it's the correct place.
yokel22
Post
by yokel22 » Sun Feb 04, 2018 8:59 pm
Beautiful, I'll get a few more of the commands going now that I can see what it's returning.
Mastiff
Post
by Mastiff » Sun Feb 04, 2018 9:10 pm
Great, thanks! And who should I pester to fix that SSL problem?
yokel22
Post
by yokel22 » Sun Feb 04, 2018 10:10 pm
I think kg fixed it. It just started working for me one day when i reinstalled rc4, when it previously didn't. Give these a shot, it's xml not just one script.
<Macro Name="Sensibo" XML_Guid="{351D723D-8A39-4611-B268-78D2FF9F7087}" Expanded="True">
<Action Name="add your api key to the first script, nothing else needs editing." XML_Guid="{C4221FD5-5685-4E3C-8BF2-8FA0A3897FEB}">
EventGhost.Comment()
<Action Name="get/set global device variables" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\n# Enter your api key\neg.globals.sensiboKey = ''\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['fields'] = 'id,room'\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/%s/measurements'\nstate = '/pods/%s/acStates'\nchangeState = '/pods/%s/acStates/%s'\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + devices, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\neg.globals.sensiboDeviceName1 = deviceDict['result'][0]['room']['name']\neg.globals.sensiboDeviceId1 = deviceDict['result'][0]['id']\n\nprint eg.globals.sensiboDeviceName1\nprint eg.globals.sensiboDeviceId1\n\n\n")
<Action Name="get device measurement" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['podUid'] = eg.globals.sensiboDeviceId1\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/%s/measurements'\nstate = '/pods/%s/acStates'\nchangeState = '/pods/%s/acStates/%s'\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + measurement, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
<Action Name="get device state" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u'import requests\nimport json\n\nparams = {}\nparams[\'apiKey\'] = eg.globals.sensiboKey\nparams[\'podUid\'] = eg.globals.sensiboDeviceId1\nparams[\'limit\'] = 1\nparams[\'fields\'] = "status,reason,acState"\n\n# command paths\nbaseUrl = \'https://home.sensibo.com/api/v2\'\ndevices = \'/users/me/pods\'\nmeasurement = \'/pods/%s/measurements\'\nstate = \'/pods/%s/acStates\'\nchangeState = \'/pods/%s/acStates/%s\'\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + state, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n')
Mastiff
Post
by Mastiff » Mon Feb 05, 2018 7:32 am
Thanks, I have opened a thread in the beta forum asking for a fix for a WIP version.
So the first code gave me this:
08:27:52 Varmepumpe ovenpå
08:27:52 oohZomrQ
Correct letters and all in the first one.
The two others gave me this:
08:31:58 Traceback (most recent call last):
08:31:58 Python script "231", line 18, in <module>
08:31:58 deviceDict = json.loads(jString)
08:31:58 File "json\__init__.pyc", line 307, in loads
08:31:58 File "json\decoder.pyc", line 319, in decode
08:31:58 File "json\decoder.pyc", line 338, in raw_decode
08:31:58 ValueError: No JSON object could be decoded
Is this a missing plug-in in my setup, or something? I have the HTTPRequest plug-in, but maybe it's another plug-in with JSON?
yokel22
Post
by yokel22 » Mon Feb 05, 2018 7:48 am
Json is formatting, like Unicode. Your not missing anything. I just made an error somewhere & there wasn't a response for it to decode. I didn't add any error handling to the scripts. I'll take a closer look in the morning.
Mastiff
Post
by Mastiff » Mon Feb 05, 2018 8:07 am
Great, thanks! It has to be pretty late there now. But I guess the SuperBowl adrenaline takes a bit of time to wind down...
yokel22
Post
by yokel22 » Mon Feb 05, 2018 5:58 pm
I didn't actually watch it. I just keep weird hours. I think i see what i did wrong. I didn't insert the podUid variable into the commands. Give these a shot, if they're okay i'll work on the last command to set the device states.
EventGhost.PythonScript(u"import requests\nimport json\n\n# Enter your api key\neg.globals.sensiboKey = ''\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['fields'] = 'id,room'\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\n\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + devices, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\neg.globals.sensiboDeviceName1 = deviceDict['result'][0]['room']['name']\neg.globals.sensiboDeviceId1 = deviceDict['result'][0]['id']\n\nprint eg.globals.sensiboDeviceName1\nprint eg.globals.sensiboDeviceId1\n\n\n")
EventGhost.PythonScript(u"import requests\nimport json\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/' + eg.globals.sensiboDeviceId1 + '/measurements'\nstate = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates'\nchangeState = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'property to change'\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + measurement, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
EventGhost.PythonScript(u'import requests\nimport json\n\nparams = {}\nparams[\'apiKey\'] = eg.globals.sensiboKey\nparams[\'limit\'] = 1\nparams[\'fields\'] = "status,reason,acState"\n\n# command paths\nbaseUrl = \'https://home.sensibo.com/api/v2\'\ndevices = \'/users/me/pods\'\nmeasurement = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/measurements\'\nstate = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates\'\nchangeState = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates/\' + \'property to change\'\n\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + state, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n')
Mastiff
Post
by Mastiff » Mon Feb 05, 2018 8:14 pm
Oh, I thought it was unamerican not to watch it, punishable by two hours of DT telling you how great and beautiful the wall will be...
OK, that worked! I must say I'm impressed by the presicion of temp and humidity:
21:09:53 {u'status': u'success', u'result': [{u'humidity': 25.699999999999999, u'temperature': 21.199999999999999, u'time': {u'secondsAgo': 31, u'time': u'2018-02-05T20:09:18.188000Z'}}]}
21:11:43 {u'status': u'success', u'moreResults': True, u'result': [{u'status': u'Success', u'acState': {u'on': True, u'fanLevel': u'auto', u'temperatureUnit': u'C', u'targetTemperature': 22, u'mode': u'heat', u'swing': u'rangeFull'}, u'reason': u'UserRequest'}]}
It seems it takes the necessary stuff out.
Posts: 5190 Joined: Fri Jun 05, 2015 5:43 am
Post
by kgschlosser » Tue Feb 06, 2018 4:35 pm
OK if you want to use requests the SSL error has a fix for it. located
HERE I have sent to code in to fix the problem . For the time being you can do the second fix that i described and it should work.
If you like the work I have been doing then feel free to
Mastiff
Post
by Mastiff » Tue Feb 06, 2018 4:38 pm
I was actually about to write that!
Thanks again!
yokel22
Post
by yokel22 » Tue Feb 06, 2018 7:46 pm
The last bit was hard to decipher. I hope these work. Try the other older scripts too, i changed them to generate events.
EventGhost.PythonScript(u'import requests\nimport json\n\nparams = {}\nparams[\'apiKey\'] = eg.globals.sensiboKey\nsensiboCurrentDict = {}\n\n# command paths\nbaseUrl = \'https://home.sensibo.com/api/v2\'\ndevices = \'/users/me/pods\'\nmeasurement = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/measurements\'\nstate = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates\'\nchangeState = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates/\' + \'property to change\'\n\nresponse = requests.get(baseUrl + measurement, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\neg.globals.sensiboLastMeasurement = deviceDict[\'result\'][0]\n\neg.TriggerEvent(prefix="Sensibo", suffix=eg.globals.sensiboDeviceName1, payload=eg.globals.sensiboLastMeasurement)\n\n\n\n')
EventGhost.PythonScript(u'import requests\nimport json\n\nparams = {}\nparams[\'apiKey\'] = eg.globals.sensiboKey\nparams[\'limit\'] = 1\nparams[\'fields\'] = "status,reason,acState"\n\n# command paths\nbaseUrl = \'https://home.sensibo.com/api/v2\'\ndevices = \'/users/me/pods\'\nmeasurement = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/measurements\'\nstate = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates\'\nchangeState = \'/pods/\' + eg.globals.sensiboDeviceId1 + \'/acStates/\' + \'property to change\'\n\n\n# First request to get devices/id\nresponse = requests.get(baseUrl + state, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\neg.globals.sensiboLastState = deviceDict[\'result\'][0][\'acState\']\n\n\neg.TriggerEvent(prefix="Sensibo", suffix=eg.globals.sensiboDeviceName1, payload=eg.globals.sensiboLastState)\n\n\n\n\n')
<Action Name="set Temp" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\n# change this value. If this errors, try '20'.\nsetTemp = 20\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['targetTemperature'] = setTemp\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/' + eg.globals.sensiboDeviceId1 + '/measurements'\nstate = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates'\nsetTemperature = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'targetTemperature'\nsetOnOff = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'on'\nsetMode = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'mode'\nsetFan = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'fanLevel'\n\n\n# First request to get devices/id\nresponse = requests.patch(baseUrl + setTemperature, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
<Action Name="set Mode" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\n# change this value, i think the other setting will be 'cooling'.\nmode = 'heat'\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['mode'] = mode\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/' + eg.globals.sensiboDeviceId1 + '/measurements'\nstate = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates'\nsetTemperature = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'targetTemperature'\nsetOnOff = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'on'\nsetMode = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'mode'\nsetFan = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'fanLevel'\n\n\n# First request to get devices/id\nresponse = requests.patch(baseUrl + setMode, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
<Action Name="set Fan" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\n# change this value, i think settings will be 'auto', 'on', 'off'.\nfanSet = 'auto'\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['fanLevel'] = fanSet\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/' + eg.globals.sensiboDeviceId1 + '/measurements'\nstate = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates'\nsetTemperature = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'targetTemperature'\nsetOnOff = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'on'\nsetMode = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'mode'\nsetFan = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'fanLevel'\n\n\n# First request to get devices/id\nresponse = requests.patch(baseUrl + setFan, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
<Action Name="set On/Off" XML_Guid="{BEEED31A-C7AF-4080-86CE-5E828329911F}">
EventGhost.PythonScript(u"import requests\nimport json\n\n# change this value, True, False.\nonOff = 'False'\n\nparams = {}\nparams['apiKey'] = eg.globals.sensiboKey\nparams['on'] = onOff\n\n# command paths\nbaseUrl = 'https://home.sensibo.com/api/v2'\ndevices = '/users/me/pods'\nmeasurement = '/pods/' + eg.globals.sensiboDeviceId1 + '/measurements'\nstate = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates'\nsetTemperature = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'targetTemperature'\nsetOnOff = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'on'\nsetMode = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'mode'\nsetFan = '/pods/' + eg.globals.sensiboDeviceId1 + '/acStates/' + 'fanLevel'\n\n\n# First request to get devices/id\nresponse = requests.patch(baseUrl + setOnOff, params = params)\njString = response.content\ndeviceDict = json.loads(jString)\n\nprint deviceDict\n\n\n\n")
