arjanm
Post by arjanm »
NateEaton wrote:Having done a little digging, it seems like as it should be possible to update the plug-in to accept a port number that would be passed in the header to the Transmit function.
Anyone else know what it would take to update this plug-in to allow us to specify which IR port to transmit on for units (like the original MCE transceiver) that supports it?
I'm also looking for this functionality since I want to control two LED-strips individually.
The header seems to be defined by this line:
header = pack(7*ptr_fmt,2,int(1000000./freq),0,0,0,1,len(transmitCode))
Can somebody explain the format of this header? What part defines the blaster port?
KairuByte
Post by KairuByte »
I don't suppose anyone is around (active) that is capable of modifying (or explaining how to modify) the service? A while back I was trying to use a harmony set up with MCE Keyboard codes (for more remote capability, more codes = more options), and wanted to properly grab them, since they don't always show up as the same unknown code.
I could never get it to compile, and there seems to be a file missing. But I could be wrong and just doing it incorrectly. Maybe someone has some idea?
nonob
Post by nonob »
I have a harmony 600 remote set as mce remote..
Before, i had a igorusb receiver, it was working fine with EG but i had 2 code received for each button pressed.
Now i have a mce RC6 receiver.
I want to use it with eg so i use this plugin.
It works well with my mce remote: i receive one code by button pressed with the good name like: mceremote.mce.up .
But with my harmony as mce remote: i can received more than one code:
mceremote.mce.up
mceremote.mce.unknow.................1
mceremote.mce.unknow.................2
mceremote.mce.unknow.................3
mceremote.mce.up
etc..
Is ther a way to avoid that ?
EvilMF
Post by EvilMF »
I recently installed EventGhost with MceRemote_Vista plugin, and almost everything is just fine.
However, I found that the plugin is unstable and stops to receive signals from the remote sometimes.
After some short study, I found that the problem is not in the Python plugin, but in AlternateMceIrService, which fails sometimes and the service just stops.
I currently have no time to investigate the issue further, so I made a quick fix which works for me (and probably would suit some of you too).
When the plugin fails to open the pipe to service (this leads to the message "MCE_Vista: MceIr pipe is not available"), probably the service is just not running.
So I added the corresponding check and an attempt to start the service automatically.
The updated plugin is attached.
One important remark: by default, the ordinary user has no rights to start and stop the service via API.
So, for this auto-restart functionality to work, you should either:
1. Use the account in Built-in Administrators group.
or
2. Set the right permissions for AlternateMceIrService service and your account (a guide can be found here: http://msmvps.com/blogs/erikr/archive/2 ... ndows.aspx).
If you don't have the right permissions, the plugin will work as previously (not trying to restart the service, just trying to read from the pipe over and over again).
MceRemote_Vista.zip
(6.98 KiB) Downloaded 362 times
nonob
Post by nonob »
About my last post, i found the problem, it is caused by use of both cheaper mce receiver and harmony remote :
http://forum.xbmc.org/showthread.php?ti ... pid1567706
cu
Post by Sem;colon »
Hey everyone,
New Version!
Added a new function "Get IR code": If triggered it turns the receiver in learn mode - after learning it returns the learned IR code as eg.result (or False if learning failed).
@EvilMF: I incorporated your Improvement - next time please check if you have the latest version before modifying a plugin :wink:
...The Plugin in the first post is outdated, but I can't change it as I didn't create the Plugin/Topic.
MceRemote_Vista v1.1.0
(28.91 KiB) Downloaded 305 times
kkl
Post by kkl »
Sem;colon wrote: ...The Plugin in the first post is outdated, but I can't change it as I didn't create the Plugin/Topic.
Sem;colon,
I'm grateful to the original author of this plug-in, but he seems to have disappeared from the forum a long time ago. Since you have graciously updated the plug-in, perhaps you could start a new thread for this version so that people can find the current version in the usual location, the first post. Thanks.
kkl
barnabas1969
Post by barnabas1969 »
@sem;colon: Is your new version based on one of the files in the first post of this thread, or is it based on a later version like the one in the post linked below?
http://eventghost.net/forum/viewtopic.p ... 160#p20128
EDIT: And, as a side note, the link above fixes the crashing issue, so there may not be a need to restart the service.
Post by Sem;colon »
Good idea!
barnabas1969 wrote:@sem;colon: Is your new version based on one of the files in the first post of this thread, or is it based on a later version like the one in the post linked below?
ha! You got me, I should maybe start following my own suggestions ;)
Anyway, I think the biggest change Stottle made was in the AlternateMceIrService.exe, so you should be able to use the newer Service from that post with my latest version of the plugin as well.
He did one more thing in the plugin itself:
I also put in a statement on the python side that says if the length of the sequence is greater than 500, drop it. Held down keys are broken into multiple sequences, so this would only throw out long sequences like noise. Don't know if this will ever trip, but it shouldn't hurt anything.
To answer your question: No, I didn't incorporate this change... And I won't until I tested it for a while.
barnabas1969
Well, when you start a new thread, you should include the newer service executable.
Post by Sem;colon »
barnabas1969 wrote:Well, when you start a new thread, you should include the newer service executable.
OK, new thread can be found here: viewtopic.php?f=9&t=6044
bxr
EG Freezes while blasting
Post by bxr »
Any idea why EG freezes sometimes while blasting an IR?
VANQ
Re: EG Freezes while blasting
Post by VANQ »
bxr wrote:Any idea why EG freezes sometimes while blasting an IR?
Yes confirm. Sometimes it freezes.
Question: this latest version of the plug-in is in the Latest release: EventGhost 0.4.1.r1722, Feb 03 2016?
Or it is necessary to install separately?
topix
Post by topix »
@VANQ: This is an old thread. Are you still using XP? Because for Vista and later there is a new one: viewtopic.php?f=9&t=6044
