Windows programs flashing in menu bar
reta
Post by reta »
Is it possible to detect when a Windows program is blinking in the menu bar (not sure what it's called, see screenshot below) with EventGhost? Programs does so in Windows when they have some kind of alert or something important is happening in the program but it's not currently in focus (and I think minimized to the start menu).
blackwind
Re: Windows programs flashing in menu bar
Post by blackwind »
Install patch, load "Task Create/Switch Events" plugin, bind macro to Task.Flashed.dota2.
patch.zip
(3.12 KiB) Downloaded 141 times
/bw
