Task Create/Switch Events Plugin problem and solution
EvilMF
Post by EvilMF »
I use PotPlayer as my primary video player, and I recently downloaded EventGhost and tried to make these two apps work together.
However, I encountered one problem: when PotPlayer window gets focus, Task Create/Switch Events Plugin doesn't report corresponding Activated event.
As a result, it is very inconvenient to use this player with EventGhost (I tried to use Process.Created event instead, but it only works once and doesn't help if the already launched app becomes active).
So, I took a look at the plugin source code, and I found that the problem is inside CheckWindow function.
The call of GetWindowLong(hwnd, GWL_HWNDPARENT) for main PotPlayer window returns a handle, so the function returns and no event is generated.
I believe that the purpose of this code is to prevent event generation for child windows (or am I missing something here?).
In that case, the code should be corrected a bit.
GetWindowLong(GWL_HWNDPARENT) does the same as GetParent function.
From GetParent description:
"If the window is a child window, the return value is a handle to the parent window.
If the window is a top-level window with the WS_POPUP style, the return value is a handle to the owner window."
Main PotPlayer window has WS_POPUP/WS_OVERLAPPED style and is owned by another WS_POPUP/WS_OVERLAPPED window with zero size (found this with Winspector; probably a strange window hierarchy).
So, main window doesn't have a parent (to be more precise, it has desktop window as a parent), but it has an owner.
The right way would be to change GetParent (which returns also the owner) to GetAncestor, as suggested in MSDN:
"To obtain the parent window and not the owner, instead of using GetParent, use GetAncestor with the GA_PARENT flag"
I changed the code in the following way:
def __start__(self, *dummyArgs):
self.desktop = GetDesktopWindow()
def CheckWindow(self, hwnd):
parent = GetAncestor(hwnd, GA_PARENT)
if parent and parent != self.desktop:
return
And everything works fine - Activated/Deactivated events for PotPlayer are generated.
Updated plugin is attached.
I haven't found any side effects with this fix, but I'm not 100% sure it is OK.
Would be glad to see some comments from the creator of this plugin.
Task.zip
(2.77 KiB) Downloaded 337 times
Re: Task Create/Switch Events Plugin problem and solution
EvilMF wrote:Would be glad to see some comments from the creator of this plugin.
I am afraid that you will not get it.
Mr. Bitmonster (author of the plugin and also the program EventGhost) completely left the project and he is not involved here at all.
If someone else does not take up with it, so I might check it out sometime (when I have time).
Note: I've never needed this plugin and I do not use it. Better would be someone who uses it.
Tryanderror
Post by Tryanderror »
Great! Thanks a lot EvilMF. :D
I tried your modified plugin today and it works as expected. This is finally the solution for my (maybe misplaced) post here: viewtopic.php?f=2&t=3599&p=21576#p21576
Best wishes
Tryanderror
