EventGhost Application Control Plugin
Re: EventGhost Application Control Plugin
Looks very cool and is working well for me so far. :)
phlox
Post by phlox »
EG App Control 0.3.1
Here's a minor update, program is unchanged, "just" the documentation has been improved - many thanks to blaher for his help :)
PS: As soon as I believe that everything is stable and final, I'll move the download to the first post. But currently I'd say it's still "beta".
(Edit: attachment removed since obsolete)
Livin
Post by Livin »
Has Pako got back to you on the incompatibility with his Log Redirector? I use Log Redirector regularly
phlox
Post by phlox »
Pako was faster releasing a new EG version with the new Log API than I was able to answer the last question :)
Even better - here follows the adapted version EG App Control 0.3.2 using the new API. It prerequisites EG version 0.4.1.r1610 (or higher)
Many thanks to Pako for his quick response!
Please remind to install newest version 0.0.7 of Log Redirector as well if you're going to use these two plugins in parallel.
EDIT: attachment removed; moved to the first post.
cfull1
Post by cfull1 »
This is awesome, thanks!
Livin
Post by Livin »
I'm trying to capture an event...
System.DeviceAttached [u'\\\\?\\DISPLAY#ONK0C81#5&30f4f1ad&5&UID1057568#{e6f07b5f-ee97-4a90-b076-33f57bf4eaa7}']
When I place that in the 'Capture Log Message' box it is not working.
I want to watch for this event and trigger another event.
thx for the help!
Livin
Post by Livin »
Livin wrote:I'm trying to capture an event...
thx for the help!
anyone?
cfull1
Post by cfull1 »
Did you check "Whole line" and "Event"?
Livin
Post by Livin »
yes, I tried several things.
cfull1
Post by cfull1 »
Did you execute the action to enable monitoring?
Livin
Post by Livin »
of course. here's a screen. you can see the line is in he log several times and EG App Control does not see it. I've tried changing about ever option in the dialog - and yes, I did check 'Fire an Event' but I turned it off just in case there was some bug and it started working for some reason.
With EventGhost 0.5.0 beta 3 it complains that the mode on line 82 is not valid. Deleting the 't', i.e.
changing it from f = codecs.open(filepath, mode="rt", encoding="latin_1", buffering=-1)
f = codecs.open(filepath, mode="r", encoding="latin_1", buffering=-1)
seems to fix it.
EGAppControl.zip
(8.02 KiB) Downloaded 179 times
