next time you should maybe ask for a solution to your problem before starting to change the plugin.
I mean, I'm sure you spent some time with the code if it's your first Python experience.
That maybe could have been avoided.
The only thing that is not possible with the plugin as it was using GET is:
To be honest I don't see a reason for this using GET, but hey, I guess you see one.Will be in the resulting XML page as ÔÇÿ<egitem name=ÔÇØTestÔÇØ>MyResult</egitem>ÔÇÖ
setting a variable with GET could have been done previously with a simple Python script like this: that's inside the script: (just one line!!)
how to use:
http://<ip or hostname>?setVar&<name>&<value>
and you will get: TADAA!! ^^
