This may work on numerous Mitsu TV's.
RS232 spec here
* file updated Nov 27 *
Mitsubishi LT249 LCD Television
- Mitsubishi LT249.rar
- (8.59 KiB) Downloaded 217 times
PanteraGSTK
Re: Mitsubishi LT249 LCD Television
I'm trying to use this plugin to power my TV on and off. This is the PDF for rs232 for mitsubishi tv's from 2003-2009 and I can't get it to work. The volume command from the plugin works so I know the TV is getting the commands. Any help would be appreciated.
The codes I've tried are.
DF8070020000 POWER ON
DF8070020001 POWER OFF
Power OFF -- DF8070F802000135
Power ON -- DF8070F802000036
check Power-- DF8070F8020080B6
