Latest version always here:
Previous version:
This is the released version of the plug-in mentioned. Install as usual with plug-ins.
For product information
http://www.kmk.com.hk/ProductShop/USB5I8O.htm
It is a bit tricky to find the required serial number of the boards, therefore the separate tool below is also provided. It requires that you first have installed the OCX and drivers which are provided on a CD with the product
KMK USB 5 Input 8 Output Channels Controller
Re: Plugin: KMK USB 5 Input 8 Output Channels Controller
EventGhost 0.4.0 update
I have updated the plugin with the mandatory GUID entry
Re: KMK USB 5 Input 8 Output Channels Controller
I have released a new version that uses eg.PersistentData to save persistent data instead of the python function pickle
No other changes are made
