by accident I noticed the AIMP MusicPlayer is (partly) compatible with the Winamp Window Commands.
So I customised the Winamp Plugin for AIMP - this is not necessarily a replacement for the other AIMP Plugin: viewtopic.php?f=9&t=4090&hilit=AIMP
I decided to create another plugin as this one uses a different method for sending commands to AIMP.
But you can combine the functionality and use both plugins!
Changelog:
v1.4:
- Some small fixes
- Plugin is now in the .egplugin format
- Added Guid, this may lead you to remove the old plugin verison before adding this one!
v1.2:
- New function "Save Playlist"
v1.4:
- Some small fixes
