Standby
Prinz
Standby
Post by Prinz »
I have written a new plugin, which offers a better control of the standby function.
The features of the plugin are:
  • Triggering the standby timer using different standby times
  • The standby timer can be enabled, which can be triggered by an application
    The standby timer can be disabled, which can be triggered by an application
    The Enable/Disable can be counted (Disable count up, enable count down). If the count is zero, the standby timer is enabled
    Different counters and standby time for different applications
    If the time between an enabling and disabling event is too long, the standby timer can be enabled after a given time. This is somthing similiar to a watch dog control. In this case a event "StandbyControl.Release.applicationName" is executed
    If the standby condition is detected, the event "StandbyControl.Trigger" is executed. Using this event, a rule can be executed, which terminates some applications before standby.
Could you give me some feedback?
Prinz
I have found a small bug, in this case the downlload file is removed
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Prinz
Re: Standby plugin
Post by Prinz »
no I have fixed the bug.
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Prinz
Re: Standby plugin
Post by Prinz »
a new release is now available.
following changes are done:
  • Some minor bugs are fixed
  • A Count Down OSD is implemented, which is creating a event named "StandbyControl.OSDCountDownFinished" if the count down is completed. It is using the OSD of the EventGhost.
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Prinz
Standby plugin new version for 0.3.7.r851
Post by Prinz »
In case of the new EventGhost version (0.3.7.r851) also a new version of the standby plugin is necessary.
Following bugs are fixed:
- Logging improved
- Standby/Hibernate improved (In some cases a standby trigger could occur on resume)
Regards
Prinz
EDIT: Attachment is removed in case of a configuration GUI bug.
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Prinz
Fix of Standby plugin for 0.3.7.r851
Post by Prinz »
I have seen, that I have attached the wrong plugin version in my last post. This version contained still a bug in the configuration dialog.
The fixed new version is attached to this post.
Best regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Prinz
StandbyControl V1.04
Post by Prinz »
New version 1.04 released.
Following features added:
  • Process monitor added
  • New actions: IsMonitoredProcessRunning, Wastriggered
  • An external OSD can be used by the OSD count down (e.g. DVBViewer-Plugin: ShowInfoinTVPic )
Regards
Prinz
StandbyControl_1_04.zip
(12.36 KiB) Downloaded 521 times
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
Re: Standby
Post by Bitmonster »
Well, I have some problem to understand this plugin. It is quite confusing for me to figure out, what it actually is meant for. For example there is a application/process list in the plugin configuration, but it doesn't show anything, even if I press "refresh". And I surely have a lot of apps/process running.
Could you give some use case, where this plugin provides a solution? Just to get "the idea" of this plugin.
Prinz
Re: Standby
Post by Prinz »
Bitmonster wrote:Well, I have some problem to understand this plugin. It is quite confusing for me to figure out, what it actually is meant for. For example there is a application/process list in the plugin configuration, but it doesn't show anything, even if I press "refresh". And I surely have a lot of apps/process running.
You are right, the term "application name" is very confusing. I think a better name should be "application status" or something like this.
E.g. the DVBViewer plugin is generating events depend on its status. If e.g the event "DVBViewer.StartRecord" is generated by the DVBViewer plugin in my setup the eg will start a macro which contains the StandbyControl action "DisableStandby". The DisableStandby is parametrized by the "Application name" and some other parameters. In this case the application name in my setup is named "DVBViewerRecord", it's a combination of the application and the status of the application. In this case the entry "DVBViewerRecord" will apear in the list of the plugin configuration and shows, that the standby timer is disabled by these "application" and it's special status.
I know that this plugin needs a (better) documentation. I will prepare a documentation with a working example in the next days.
Regards
Prinz
EDIT:
This plugin is a replacement of the windows internal standby detection. The normal windows standby detection should be disabled. If the plugin has detected, that a standby is recommended, a EG event named "StandbyControl.Trigger" will be fired. Using this event, a EG macro should be executed, which can check some other standby related things and if the standby is possible, the EG action "System.Standby" should be executed by this macro. This trigger can also use for starting a count down.
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
schindi77
Re: Standby
Post by schindi77 »
Hello!
I┬┤ve got some problems with the CancelOSDCountdown function of the plugin.
I┬┤m starting a countdown when shutting down DVBViewer. During this time I┬┤m able to cancel the shutdown with a defined remote button.
But using the CancelOSDCountdown doesn┬┤t cancel the countdown. It runs to zero and fires the defined end-event.
What do I do wrong? Is there a special trick how to use it?
P.S.: We can also talk german....I know you from the german DVBViewer-forum.....
Prinz
Re: Standby
Post by Prinz »
schindi77 wrote:I┬┤m starting a countdown when shutting down DVBViewer. During this time I┬┤m able to cancel the shutdown with a defined remote button.
I'm using the CancelOSDCountdown in the same way.
Which OS are you using?
Could you sent me your setup (eg PM)?
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
schindi77
Re: Standby
Post by schindi77 »
Hi!
Thanks for your reply!
I┬┤m using Vista 32bit.
I┬┤ll send my setup to you when I┬┤m at home....
Best regards
