KMPlayer
Milbrot
KMPlayer
Post by Milbrot »
I have created a plugin for KMPlayer.
Milbrot
KMPlayer.zip
Version 1.0.348
(13.59 KiB) Downloaded 1808 times
petarl
Re: KMPlayer
Post by petarl »
EventGhost won't load it... at least mine won't.
It says it can't load __init__.py
Milbrot
Re: KMPlayer
Post by Milbrot »
You have more information?
Milbrot
petarl
Re: KMPlayer
Post by petarl »
When I go to Configuration -> Add plugin in EventGhost I get message in the left windows that says "Can't read __init__.py for plugin "KMPlayer"". I use Eventghost 0.3.5c.908.
Milbrot
Re: KMPlayer
Post by Milbrot »
You should use latest beta version and see if your problem persists.
Get it here http://www.eventghost.org/downloads/Eve ... _Setup.exe
Milbrot
toothrot
Re: KMPlayer
Post by toothrot »
Milbrot,
How did you get the commands? I want to add support for Open album art...
Thanks for your help and work..
toothrot
Milbrot
Re: KMPlayer
Post by Milbrot »
I have the commands from http://www.kmplayer.com/forums/showthread.php?t=10546
This file is old and have no commands for Open album art.
In the past i do a short look for a solution to remote control Open album art but no luck.
I think you can only ask in kmplayer forum for a possible solution.
Milbrot
toothrot
Re: KMPlayer
Post by toothrot »
Thanks Milbrot, I will let you know if I make any headway with it...
scorpie
Re: KMPlayer
Post by scorpie »
I want to use this plugin, but when I add it I get this massage " KMPlayer installation path not found!" Hm I think I know why, KMPlayer is installed in D:\Media\The KMPlayer. What do I have to change that the plugin is working?
scorpie
So I solved it, it is working. I had to change the path from Software\\KMPlayer\\KMP2.0\\OptionArea to Software\\KMPlayer\\KMP2.0\\OptionList\KMPWizard
Thanks for the plugin
mcu2005
Re: KMPlayer
Post by mcu2005 »
I'm new comer, and what to add KMplayer Plugin too.
My system XP Pro SP3, Event ghost version 0.3.7.r1194
And I have same problem that it said the KMplayer installation path not found.
Can anyone told me how to change the path setting?
thanks a lot.
scorpie
Re: KMPlayer
Post by scorpie »
locate the path in the registry and edit the file located in the kmplayer plugin folder
reeven
Re: KMPlayer
Post by reeven »
working ok this plugin, but how to use this plugin without focus on kmplayer?
Without focus remote buttons does not respond to kmplayer.
scorpie
Re: KMPlayer
Post by scorpie »
what do you mean without focus on kmplayer. i am german, so my english is not the best one.
you can try the funktion find window (kmplayer) and then bring it to the front - it should be the active window now, maybe this helps.
fabad
Re: KMPlayer
Post by fabad »
Milbrot wrote:I have created a plugin for KMPlayer.
Milbrot
Wonderful! Thank you very much!
defender013
Re: KMPlayer
Post by defender013 »
Hi all,
I've downloaded this plugin into EG, and it has loaded correctly for me, and all seems to be running smoothly except for a small problem...
Certain button on my remote by default trigger certain HID functions (HID.button7 and HID.button9) on my setup. This is not so bad, except KMPlayer takes these commands and performs some function immediately. EVEN if i have these buttons bound to a different function through the KMPlayer plugin.
does anyone have any advice on this? I basically need to somehow stop KMPlayer for responding to HID commands and respond only to keyboard commands. any help would be much appreciated.
Many thanks,
defender013
