RBS_Vader wrote:I checked everything. But no luck at all. Will wait till next XBMC2 release.
Hmm, I moved my
XBMC settings dir, so
XBMC created a new config and I didn't have to do anything in
XBMC for it to work. So only thing needed should be to have the correct IP in XBMC2, and if you run both
XBMC and EventGhost on the same computer the default IP should work.
Only things I can think of:
Did you check this (Settings\Services\
Remote control) needs "
Allow programs on this system to control XBMC" to be checked, you didn't mention it.
Try putting your actual IP in the XBMC2 config.
Other then that maybe something is conflicting with the
port 9777 that XBMC2 is using to send the commands (The port setting in XBMC2s config is for HTTPAPI only)
I don't think the next release is going to help, as I'm not planning any changes in how the actions are sent to
XBMC, as they seem to work correctly. But I'll see if I can improve detecting connection problems.
