Frosty1981 wrote:Is there any plan to implement iPhone support as well from the PC end of things for sending sms from pc to smartphone?
It seems that you have a rather distorted ideas about the possibilities Eventghost within Pushbullet. Pushbullet plugin (within Eventghost), it is only one Pushbullet device and it can not offer any features that Pushbullet as such, does not have in its bid.
I do not know why Pushbullet developers do not offer this feature. How do I send text messages from my computer?
Maybe iPhone operating system does not allow this.
Maybe that is why the move to Android.
I'm sorry, but it is a bug, that prevents write "Request error".
Please, before being released a new version, open the file __init__.py in Notepad.exe, and modify the line 3401 as follows:
I've opened it with Notepad, but I can't find my way in this file, I can't recognize line 3401, sorry for being a noob..
Do you have any advice on 2 minutes PushBullet: Channels received: [] PushBullet: Targets derived: [] PushBullet: Devices derived: [] loop?
I've contacted PB developers and waiting for them to response.
1) Please enable the "Status bar" in the Notepad.exe. Then you will see a line where you are. Or you can use the search function to find the string reqErr.
2) I think PB devs can not help in this case.
The version 0.2.13. works without error messages in red, but there's the initial problem again:
my Pushbullet actions are executed for a minute or two, but I'm also getting: PushBullet: Channels received: [] PushBullet: Targets derived: [] PushBullet: Devices derived: []
messages constantly in that period and then I get "ratelimited for performing too many requests/ops in a short period of time."
Please set the Logging level = 5.
Then send me EventGhost_Log.txt file to the address found in the PM.
You obviously have to wait for some time to avoid (at least initially) ratelimit problem.
I do not know how it works, I've never met ratelimit.
It might also help to attach your EventGhost configuration file (XML).
Note:
Are you sure that you have properly configured API key and unique device nickname?
