Hi Jonib,
is there a way to get the stereomode of an playing movie over json? Or the complete filename? When i try to select Player and getitem i got a error that the playerid is missing, but i dont know how i could ad it...
All I found is a "stereomode" in the "streamdetails" property but that is always empty for me. You could ask in the Kodi JSON-RPC forum about it if you want here.MaxMan23 wrote:is there a way to get the stereomode of an playing movie over json?
Sure example below.Or the complete filename?
You need to get the "playerid" first with "Player.GetActivePlayers".When i try to select Player and getitem i got a error that the playerid is missing, but i dont know how i could ad it...
Put this in a macro to get info on a currently playing video:
XBMC2->JSONRPC->Player.GetActivePlayers with no parameters.
XBMC2->JSONRPC->Player.GetItem with parameters: [{{eg.result[0]["playerid"]}},["file","streamdetails"]]
["file","streamdetails"] is a list of properties you want to get, here is the list of properties that you can use.
Ask again if you need more details.
Hi in the Json Forum they wrote:
You should be able to use GUI.GetProperties method adding a steroscoicmode property like such:
{"jsonrpc":"2.0","method":"GUI.GetProperties","params":{"properties":["stereoscopicmode"]},"id":1}
that should give you a result of the current mode like such:
"stereoscopicmode": {
"label": "Over/Under",
"mode": "split_horizontal"
How can i test it, could you help me (at moment i am at work, i can try this at home)
Just paste this in a JSONRPC action:MaxMan23 wrote:Hi in the Json Forum they wrote:
Put Kodi to sleep while recording
I didnÔÇÖt found an appropriate answer for my problem, so I try to ask by myself.
I got a HTPC running Windows 8.1 with MediaPortal an Kodi 14.2; I have an One4all remote with a Flirc IR.
My system wakes up and goes to sleep automatically when I program a timer to record a tv show. So far so good. Now my problem: I want to send my HTPC to sleep when I donÔÇÖt use it. It works like a charm and also I can wake up without problem. The only issue: If a recording is active, it will stop this and sends my PC to sleep.
I would like to have a macro that is able to check if a recording is active or not.
I played a little bit around and found out that JSON could be my solution If a recording is active I get
if not
But how can I use it to jump from my shut down macro to cancel or to hibernate?
I hope I have explained it clearly enough.
"recording":trueCode: Select all
"recording":falseI hope I have explained it clearly enough.
Re: Put Kodi to sleep while recording
Now I found a solution for a similar problem. Maybe someone can help me to find the correct code. In this example it evaluate if Kodi is running minimized.
viewtopic.php?f=9&t=1562&hilit=jump&start=300#p20223
This should give you the True/False part that you can test:hidalgo wrote:If a recording is active I getif notCode: Select all
"recording":trueBut how can I use it to jump from my shut down macro to cancel or to hibernate?Code: Select all
"recording":false
{eg.result["recording"]}For example put this in a "Python command" action, after the JSONRPC action:
eg.result = eg.result["recording"]jonib
Thank you jonib. Now everything is working like expected.
laestrella
I need some help.
I'm trying to get JSONRPC working with no luck. I get a notification in the log on the left side of eventghost saying that JSON-RPC is connected and HTTP API connected but when I go to configure the JSONRPC plugin I get an error saying error opening jsonrpc.dat. Even kodi brings up a notification saying that eventghost is connected.
Any ideas what I'm doing wrong?
What version of the plugin? What version of Kodi?laestrella wrote:I'm trying to get JSONRPC working with no luck.
That error shouldn't be a problem, either the plugin should update the JSON commands automatically or you can press the update button. What happens after?but when I go to configure the JSONRPC plugin I get an error saying error opening jsonrpc.dat.
OK, so you get a connection to Kodi so your IP setting in the plugin is correct.Even kodi brings up a notification saying that eventghost is connected.
Is the setting "Allow control of Kodi via HTTP" activated in Kodi?Any ideas what I'm doing wrong?
laestrella
I had an old version of the plugin running...used the download from the first postjonib wrote:What version of the plugin? What version of Kodi?laestrella wrote:I'm trying to get JSONRPC working with no luck.That error shouldn't be a problem, either the plugin should update the JSON commands automatically or you can press the update button. What happens after?but when I go to configure the JSONRPC plugin I get an error saying error opening jsonrpc.dat.OK, so you get a connection to Kodi so your IP setting in the plugin is correct.Even kodi brings up a notification saying that eventghost is connected.
Thank you. It works now.
Yeah it's really old unfortunately, I haven't made a "proper" release so I haven't updated the first post with the beta/test versions I have released. But now it is mostly useless so I have removed it.laestrella wrote:I had an old version of the plugin running...used the download from the first post.
Great.Thank you. It works now.
laestrella
I'm back with one more issue.
So I've installed eventghost on another machine with the new plugin. And none of the macros are working. It's so bizarre. The macros trigger with the remote but then they don't result in anything happening in kodi. So eventghost is doing it's job but then kodi doesn't respond. The ports are correct. The plugin is the same one that I have on the other computer...Not sure what's going on.
What have you tried that don't work? attache what EventGhost is logging.laestrella wrote:So I've installed eventghost on another machine with the new plugin. And none of the macros are working. It's so bizarre. The macros trigger with the remote but then they don't result in anything happening in kodi.
Have you tried the "Test" button in the settings?
Are you getting any errors in EventGhost or in Kodi? (check/post the log from Kodi, info here )
laestrella
Forgot to update but....jonib wrote:What have you tried that don't work? attache what EventGhost is logging.laestrella wrote:So I've installed eventghost on another machine with the new plugin. And none of the macros are working. It's so bizarre. The macros trigger with the remote but then they don't result in anything happening in kodi.
I rebooted and that fixed the issue. I was beyond annoyed that solved the problem. I was driving myself crazy opening and closing both programs because it didn't make any sense. So I just rebooted the computer and then it worked. Sorry to waste your time.
