jesterod
Re: XBMCRepeat XBMC plugin based on the official plugin
Post by jesterod »
kricker wrote:Can you explain this again? You want a macro to switch between screens within XBMC or between XBMC and another app? I'm not sure what an "ip" is.
i want to switch between computers running xbmc ip=127.0.0.1 like i hold zero for 1.5sec and it starts sending the butten press's to a different version of xbmc
jesterod
Post by jesterod »
jonib wrote:So you want to control two different XBMCs?
Then you need two XBMCRepeat plugins in the autostart folder, configured to use the right IP numbers.
Then you need to make a macro to enable one XBMCRepeat macro tree and disable the second XBMCRepeat macro tree, and vice versa. Using Exclusive enable a folder/macro or Enable/Disable an item.
yea that what i thought and tryed to do but i couldent get it to load 2 copys
jesterod wrote:yea that what i thought and tryed to do but i couldent get it to load 2 copys
What version of EventGhost do you have?
And when you try to add the second XBMCRepeat what happens?
At least on my EventGhost ver 0.3.7.r1462 I have two XBMCRepeat plugins one controlling XBMC on this computer and the second controlling XBMC on my XBOX.
jesterod
Post by jesterod »
ok heres what i got but it does not work it switches but both on and off at the same time
jesterod
Post by jesterod »
jonib wrote:At least on my EventGhost ver 0.3.7.r1462 I have two XBMCRepeat plugins one controlling XBMC on this computer and the second controlling XBMC on my XBOX.
thats exactly what i want it to do ver 0.3.7.r1436
kricker
Post by kricker »
I don't think you want to disable/enable the plugins. You want to switch between the XBMCrepeat macro trees. You should have 2 sets of those in your Context Folder (hopefully that is where you put them).
Context Folder
-XBMCRepeat
-XBMCRepeat#2
jesterod
Post by jesterod »
ok i got it to work
EDIT:added a sound notfiy on switch
jesterod wrote:ok i got it to work
Damn, I don't like this at all, I made a bunch of screenshots showing how I control stuff and then you go and figure it out. :twisted:
jesterod
Post by jesterod »
awww im sorry you can show them if you want :wink:
i wouldent mind seeing your config anyway prolly damn cool
kricker
Post by kricker »
LOL. I figured you were making screenshots of it all, that is why I hurried up and just posted basic text ;)
jesterod wrote:awww im sorry you can show them if you want :wink:
I guess the big difference between mine and your config is that I separate the control of what program is controlled to a separate folder Program Control
And have the program specific folder in a subfolder Context folder and the advantage is that the Enable exclusive action only effects that folder and I can have global macros active.
kricker wrote:LOL. I figured you were making screenshots of it all, that is why I hurried up and just posted basic text ;)
I call that cheating. :x
jonib :wink:
jesterod
Post by jesterod »
that looks complicated ass hell yesterday was the first time i used eventghost im not even sure what you doing lol
jesterod wrote:that looks complicated ass hell yesterday was the first time i used eventghost im not even sure what you doing lol
It's not THAT complicated, but as my EventGhost controls more than XBMC it needs to be a bit more complicated. 8)
jesterod
Post by jesterod »
does any one know a way to close an app like kill prossess from eg?
i know it has sothing to do woth this plugin but you guys sem to know what your doing
