Serial Plugin
- Bitmonster
device = "AV2"
serial = eg.Plugin.Serial2
def printhex(bytes):
print " ".join([("%0.2X" % ord(x)) for x in bytes])
serial.Write("*")
serial.Read()
eg.Wait(0.025)
serial.Write("*" + device + " \x69\xFF")
response_length = len(device) + 8
response = serial.Read(response_length, 1.0)
printhex(response)
if response.startswith("#" + device + " \x69"):
val = ord(response[response_length - 3]) & 0x7F
val += 1
print val
val = max(0, min(val, 99))
print val
eg.Wait(0.1)
serial.Write("*")
eg.Wait(0.025)
cmd = "*" + device + " \x23" + chr(val) + "\xFF"
printhex(cmd)
serial.Write(cmd)
response = serial.Read(len(cmd), 1.0)
printhex(response)
- Bitmonster
- Bitmonster
- Bitmonster
Mach mal ein Python-Script direkt hinter dem Serial-Plugin f├╝r den naim im Autostart-Makro und f├╝ge da folgendes ein:
Weiter einstellen brauchst du da nichts. Dann startest du EG neu und f├╝gst noch diese Befehle in deinen Baum ein:
Jetzt noch die Tasten der FB zuweisen und dann sollte er zucken.
device = "AV2"
serial = result
from time import sleep, clock
class naim:
def __init__(self):
self.last_cmd_time = 0
self.volume = None
#self.GetVolume()
def SendCommand(self, cmd):
time_diff = clock() - self.last_cmd_time
if time_diff < 0.1:
sleep(0.1 - time_diff)
serial.Write("*")
serial.Read()
sleep(0.025)
serial.Write("*" + device + " " + cmd + "\xFF")
self.last_cmd_time = clock()
def GetVolume(self):
self.SendCommand("\x69")
if (response.startswith("#" + device + " \x69")
and len(response) == response_length):
self.volume = ord(response[response_length - 3]) & 0x7F
eg.PrintError("can't get volume from naim!")
self.volume = None
return self.volume
def SetVolume(self, volume):
if volume > 99:
volume = 99
elif volume < 0:
volume = 0
self.SendCommand("\x23" + chr(volume))
self.volume = volume
def ChangeVolume(self, offset):
if self.volume is None:
self.GetVolume()
if self.volume is not None:
self.SetVolume(self.volume + offset)
eg.Global.naim = naim()
<EventGhost Version="442">
<Macro Name="Increment naim AV2 volume">
EventGhost.PythonCommand(u'naim.ChangeVolume(1)')
EventGhost.AutoRepeat(0.59999999999999998, 0.29999999999999999, 0.01, 3.0)
<Macro Name="Decrement naim AV2 volume">
EventGhost.PythonCommand(u'naim.ChangeVolume(-1)')
- Bitmonster
- Bitmonster
- Bitmonster
- Bitmonster
