Mouse Emulation - cursor only moves correct when EG in focus
kfoster04
Re: Mouse Emulation - cursor only moves correct when EG in focus
Post by kfoster04 »
sstarcher I have never been able to solve this problem, so I have switched to using HIP for my mouse control. It works correctly and I have had no problems. You just have to have an extra app running in the background, I would have preferred only running EG but since I could not solve the problem, have no choice. Just a suggestion for you to try, if you are ready to give up like I was.
Home Automation, Personal Security and Gadgets - Automating your World at http://www.HaWorldOnline.com
sstarcher
Post by sstarcher »
what's HIP?
kfoster04
Post by kfoster04 »
HIP stands for "Human Interface Programmer". Here is the definition from the website where you can download the software,
"HIP is a Windows-based simple and highly configurable system that can allow you complete control of up to 81 different applications with a minimum of keys (all of which may be customised). Originally written to replace the software that was supplied to control the remote control of the Vision Plus DTV card, the system has grown to allow users a variety of interfaces which provides system control when a keyboard or mouse is not available particularly for Home Theatre PC (HTPC) users."
You can learn about it and download the software here;
http://www.byremote.com.au/HIP/
dopdahl
Post by dopdahl »
And the thread ends here? I have the same problem...3 years later...
It seems like the mouse is captured to a zero sized window in the upper left of the desktop...
Meh.
hotbuddha
Post by hotbuddha »
Strange. I do mouse movements in my plugin and no one using it has reported this issue. But I use Mouse.MoveRelative not Mouse.GoDirection.
kfoster04
Post by kfoster04 »
dopdahl wrote:And the thread ends here? I have the same problem...3 years later...
Meh.
Meh I was never able to get this working, no one responded to help so after trying other solutions to no avail I finally gave up a year or two ago and started using other programs to run the PC and mouse.
dopdahl
Post by dopdahl »
It's Alive! (the thread that is, hehe)...
Ok, I'm closing in on this one.
This appears to be associated with the EventGhost user interface behaving oddly/badly.
My first hunch is that this problem only exists on 64-bit versions of Windows. Can anyone confirm what OS they are seeing the issue on?
I have Win7 32-bit at work, and there are no problems. Works just fine.
I have a brand spanking new 64.bit Win7 system at home and it exhibits the problem.
I have also noticed that the EventGhost UI is screwed up on my 64bit machine. Can anyone verify weird vertical splitter drawing when you attempt to click and drag the splitter between the log and macro window?
On my 64bit machine dragging that splitter draws it offset from the location of the mouse (a classic indication of improper ClientToScreen and ScreenToClient processing in the UI), on my 32bit machine the UI works as expected. There is something going on with regard to the UI and mouse clipping rects or position mapping on 64bit windows that is causing the problem. When I get home, I'm going to tweak the mouse plugin to force a full screen clipping rect right before calling SetCursoPos... If it works, I'll post the hack up here. I'm not sure if it will work given that there is something more fundamentally screwed up with the application's UI on my 64bit machine.
I'm a developer by trade, I'll get to the bottom of this.
Please confirm what I've observed if you're having the problem as well.
Dave
dopdahl
Post by dopdahl »
lol kfoster...
Meh. was an expression of my disgust... not my name! lol.
Anyway, thanks for the response... I'll update my results...
dopdahl
Post by dopdahl »
Ok, either this is a bug in the auiManager class in the python version EG uses, or it's a problem in the way EG has written its code that uses auiManager.
I'm a Windows guy, not a Python guy, so I'm going to try my ClipCursor hack later... If that works, I'm good.
Otherwise, maybe there's a Python guru out there who knows what I'm talking about and can take a quick look.
Feedback later tonite.
dopdahl
Post by dopdahl »
SOLVED.
Tried my ClipCursor code and it didn't work at all.
Poked around with the 'Compatibility' settings in the Windows 'Properties' dialog for EventGhost. This is the dialog you get when you right click on the app or app icon and select properties.
I'm running 64bit windows 7 so I tried changing the compatibility modes... no difference, bug still there...
Then I realized that since I'm using this on a 60" display that I had gone into my display settings and setup my text for high DPI (larger fonts) so that I could actually read stuff from my couch.
Turns out the compatibility tab allows you to 'Disable display scaling on high DPI settings'
Checking that fixed the problem. Works fantastically well now and fixed the weird UI issue I was seeing with the splitter bar in EventGhost as well.
Hope this is a help to others.
Dave. 8)
scrambles27
Post by scrambles27 »
Nearly three years later and this thread bailed me out, thank you so much Dave. Just recently switched my HTPC to an older 1080p display with bad text display so I had to up my text size to "Larger" (150%) and my auvisio remote mouse was stuck in the corner unless the eventghost program window was in focus. I was baffled I found this thread and your suggestion of changing the high DPI compatibility setting fixed it! Hopefully bumping this will help someone else, what a weird bug. I'm running 0.4.1.r1669 btw.
