Over-riding/intercepting MCE buttons [HID plugin]
joetraff
Re: Over-riding/intercepting MCE buttons [HID plugin]
Post by joetraff »
adeb2 wrote:Looking at the plugin source for MceRemote, there is a registry key that disables the HID service.
Maybe, your RF remote has an identical registry entry that you can be disabled.
The key for the IR remote:
Registry key -
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidIr\Remotes\745a17a0-74d3-11d0-b6fe-00a0c90f57da
Registry value - CodeSetNum1
Registry value - CodeSetNum2
Registry value - CodeSetNum3
(where the CodeSetNumX entries must be deleted )
You might have some entries like HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidRf
I found some additional info, which also has a utility to tweak settings but it might only be for XP media center:
http://www.eggheadcafe.com/software/asp ... e-can.aspx
http://lb1.www.ms.akadns.net/downloads/ ... laylang=en
Good luck
The info helped a lot.
Keep it up.
I'm a web designer and here are two of my sites
how to make money online and
debt solutions
benissimo
Post by benissimo »
Very interesting thread guys - thanks for posting!
martian_aphid sounds like you've been going through exactly the same process as I have. XBMC, Emprex remote, Eventghost - then lots of fiddling with events, key mappings, HID services etc
I intend to follow your final steps as it looks like you've got it all working. And this might be enough to do the trick.
However... the other option I'm looking into is just to buy a different remote (!). One that has an eventghost plugin already, and an XBMC keyboard xml - so it will just work straight away with no fiddling. Time taken to sort all this stuff out = LOTS. Cost to buy a remote that works out the box = NOT MUCH.
This also means I can get one with backlit keys - something I didn't realize I would need until I started using the remote in a darkened home-theatre setup!
Anyone care to make a suggestion?
Ideally RF as I need a range of around 8m (though I do have line of sight to the receiver)
Must have a USB dongle-style receiver
Must have backlit keys
Must have plugins for eventghost
Must have xbmc mapping
Must work out the box!
Ben.
