SleepTimer like on TV
wakko
Re: SleepTimer like on TV
Post by wakko »
It is also can be possible IR incompatibility with such kind of EventGhost actions (which depending on key pressing time).
I'm using "homebrew" IR receiver, connected to the sound card line input together with WINLIRC.
Zhan
Post by Zhan »
wakko it's ok now. I have hardware problem with my remote. When I use the keyboard to operate the plugin it's work as you say. Unfortunetly my remote control works only in raw mode and send lot of garbage :(.
Anyway, big thanks for your help
