I've an issue. When no window is open, just the desktop, it doesn't work.
If there is a little window : then it's working. When I have tested few days ago, there was a open window ==> it was working.
What can I do?
Thank you.
WindowState? If fullscreen do A. If not do B.
Re: WindowState? If fullscreen do A. If not do B.
I have an issue with the script. Sometime it's working sometime not.
The script is OK until I click on the wall paper. If I click on the task bar, or a window the script works again.
Can you help me? Please...
It is possible, but I have a problem.FCB38 wrote:I've an issue. When no window is open, just the desktop, it doesn't work.
What can I do?
I do not know how I have to create this situation in my computer. I tried, but in vain.
What happens when it does not work?
You can attach any logos or pictures?
When I minimize XBMC by pressing a key on my remote it's working. The script see that I'm in FullScreen then it jump to minimize function. No problem.
XBMC is minimized, I can work on my computer (FireFox, MS Word, anyway...). When I finish my work and I want XBMC on FullScreen, I click on the same button of my remote. The problem is here:
What can I do? Is there a problem in my EG program?
Thank you for your help!
- If I click on the wall paper just before the remote, the script say that I'm on FullScreen mode; then I jump to Minimize function. It's not OK.
- If I don't click on the wall paper just before the remote, the script say there is no FullScreen mode; then I jump to Maximize function. It's OK.
You've probably overlooked what I wrote:
So again I must repeat what I wrote earlier:
Each application has it differently.
I know it only for Media Player Classic. I do not use other programs.
As we can see, so in your case the condition is not met.Pako wrote:It is possible to reformulate the task as follows ?
If some window of some program is just full screen and is on top, do A, otherwise do B.
If so, then it would probably be possible to find universal solutions.
You must know the name and/or class name of full-screen window.Pako wrote:I know, why you got no answer.
On your question nobody knows the answer. There is no universal way.
Where can I find the name and/or the class name of XBMC?You must know the name and/or class name of full-screen window.
And when I find this where I write it in the script?
Thank you.
Ask for it in topic Support for XBMC2 plugin (formerly XBMCRepeat).FCB38 wrote:Where can I find the name and/or the class name of XBMC?You must know the name and/or class name of full-screen window.
It is possible that jonib to add this feature to his plugin.
As you suggest I go to the topic "Support for XBMC2 plugin" : viewtopic.php?f=9&t=1562.
I explain to Jonib and he give me a solution. And it's working!!! Thank you Pako, thank you Jonib.
For me the item is closed.
