Hi. Sorry for me English)
I have a same problem with PotPlayer on Win7 32bit. Activation of PotPlayer detects as "Task.Activated.Desktop"
On other machine with WinXP 32bit detects as PotPlayerMini.
Remote - MCE REmote.
Any ideas?
Winamp detected as "task.activated.desktop"
themaster1
Re: Winamp detected as "task.activated.desktop"
I'm on win7 x64 ultimate winamp activation event is like on Xp: Task.Activated.winamp
You can also use : Process.Created.winamp it will only work for a first activation not reactivation though
I don't understand why you have Task.Activated.winamp and not me, any ideas ?
themaster1
I'm not sure but i think your winamp is integrated within the "bar" if you know what i mean. You should try to install another version separately or somehow unattach winamp of the bar.
I don't understand, what is "bar" ? How do unattach winamp from it ?
themaster1
The taskbar but i'm just guessing here.
Do you have a winamp folder in program files ? If there is what happen if you launch the .exe ?
It works !
I had to check "display in "taskbar" in winamp^, thanks for your help
Maybe it could help for potplayer too...
Bye
Bye
For a PotPlayer solution, please see the following topic: viewtopic.php?f=4&t=5890
