EventGhost with WMC remote
Mythra
Re: EventGhost with WMC remote
Post by Mythra »
Livin wrote:I just re-read the thread on the plugin ( viewtopic.php?f=9&t=1838)
I initially perused that thread, but got lost after awhile and wasn't sure what info was applicable (it goes back to 2006).
Livin wrote:found something that 'might' accomplish what you are looking for... viewtopic.php?f=9&t=1838&start=45#p21614
Thank you, that looks like it's exactly what I need. Just EG without the plugin. It can still detect remote events so I can add the TV power functions in without interfering with the normal operation. I'll try this in a few days when there is a gap in the HTPC's recording schedule where I can work on it without interfering with anyone's shows getting recorded.
Livin wrote:Anyway, try a completely new install of EG... uninstall EG and reinstall making sure to use the latest version, then install the MCE plugin.
It will be. I had to uninstall both EG and the default WMC remote drivers, then reinstall the latter when I couldn't get it working initially. :) I'll create a restore point, then uninstall Intelliremote and give this a shot.
