Wifi status notifications (DLink DIR-655)
Scope
Re: Wifi status notifications (DLink DIR-655)
Post by Scope »
krambriw wrote:I hacked your version a bit, maybe not the most beautiful and efficient code, but now I see connects & disconnects coming into the log...
Most changes was needed in the "parse_wifi_assoc_reponse" function.
If you do a file compare, you will easily see the modifications.
BR Walter
PS I notice that you many times end lines with a ';'
This should not be in Python
Hey again,
I have added parsing of the altered xml-response from the newer firmwares now.
And the semicolon is just an old habbit, which even the python-team seems to have some understanding for (since they are allowing it) :P
Kind regards,
Torbj├Ârn Westerlund.
Hi Thorbj├Ârn,
I think your latest version works ok, there are some limitations, I assume it is because the response is not holding all data anymore. If you look below, I have for reference pasted some events I receive.
Kind regards, Walter
(PS How did the TellStickDuo plugin work for you?)
19:05:30   dir655.Wifi.Quality.Stable.14d64d50571e {'quality': 96}
19:05:42   dir655.Wifi.Quality.Change.003c05003925 {'last_reported_quality': 0, 'quality': 95, 'change': 95}
19:05:54   dir655.Wifi.Quality.Change.0004201ed335 {'last_reported_quality': 0, 'quality': 96, 'change': 96}
19:07:06   dir655.Wifi.Quality.Stable.003c05003925 {'quality': 95}
19:07:18   dir655.Wifi.Quality.Stable.0004201ed335 {'quality': 94}
19:12:42   dir655.Wifi.Quality.Change.003005002667 {'last_reported_quality': 0, 'quality': 96, 'change': 96}
19:28:21   dir655.Wifi.Connected.7cc3a116a974 {'ssid': 'Unknown', 'ip': u'192.168.10.104', 'rate': 58.0, 'type': u'11n', 'quality': 100, 'channel': 0}
19:28:57   dir655.Wifi.Disconnected.7cc3a116a974 {'ssid': 'Unknown', 'ip': u'192.168.10.104', 'rate': 58.0, 'type': u'11n', 'quality': 100, 'channel': 0}
19:30:09   dir655.Wifi.Quality.Stable.003005002667 {'quality': 100}
Scope
Post by Scope »
krambriw wrote:Hi Thorbj├Ârn,
Glad to hear that it is working now! You are correct about the limitations which are SSID and Channel which are not supplied by the new firmware.
It might be supplied if you add a Guest-network with another SSID. Just a guess though!
SSID and channel may be collected elsewhere, but it would be nice to know which SSID the connection comes from, if you are using a guest-network.
Tellstick DUO plugin worked like a charm, thanks! I had to cast some var to bool before I got i to work though, but not a big hazzle... let me check which line it was...
On line 988:
bDebugCtrl.SetValue(bool(bDebug))
Perhaps I should've posted that in the Tellstick DUO-thread instead :D
Kind regards,
oncemore
Post by oncemore »
This could be pretty useful.
Would it work on my DIR-615?
