Event on monitor standby?
sea3pea0
Re: Event on monitor standby?
Post by sea3pea0 »
This thread has the answers you seek: viewtopic.php?f=2&t=2549
If you replace PowerBroadcastNotifier.py in the plugins/system folder with the modified one then you will get monitor power on/monitor power off events when windows turns on/off your display according to your power saving settings.
:D
Saxtus
Post by Saxtus »
sea3pea0 wrote:This thread has the answers you seek: viewtopic.php?f=2&t=2549
:D
Thank you so much, but unfortunately the reason I wanted it, is now long gone.
However, I will keep it in mind and I might think another use for it, just for the sake of using it!
jonib wrote:Edit: @Saxtus, Thanks for the Flattr. You doubled my Flattr count yay. :D
Thanks to @sea3pea0 bumping this thread, I've just seen your edit.
You're welcome!
I think someone else had flattred you between your edit and now, I see 3 flattrs!
