MusicBee
Re: MusicBee
Sem;colon wrote:-Repeat one Track
That to me is a bit tricky topic.
MusicBee API (and for this reason, any plugin also) has no option to set this mode.
This is a known deficiency of MusicBee API.
Too bad that at the moment MusicBee forum is out of service (server problem).
Otherwise, you would have a chance to read my discussion with the author on this topic.
I do not understand his attitude, but I have to respect that.
In a nutshell:
This is apparently due to backward compatibility with existing plugins.
I propose a suitable solution, but the author does not want to deal with.
I promised that I will no longer have any comments related to this theme.
So it would be advisable to anyone else was involved in it ...
You're not the first, also on MusicBee forum one user of plugin already pointed out.
Sem;colon wrote:-Change Playing Track in the now playing list by index
It works.
Give into a configuration consecutively two actions: Now playing list - Get file URL: <INDEX> and Now playing list - Play now: {eg.result}.
The <INDEX> can of course be something like {eg.event.payload}.
Sem;colon wrote:-Save Now Playing list as file (.m3u) at a specific location
-Duration of now Playing list (total)
-Total number of tracks in the now playing list
I do not think this is the function that is necessary to have the remote control.[/quote]
However, everything can be done in EventGhost using a simple script (tracks count even without a script).
If this was the only obstacle for you, I can easily add it all to the plugin.
Sem;colon wrote:-Get Title of a track in the now playing list (not the trackTitle in file Tag but the one that the player shows!)
I do not see a difference. Can you give an example?
Sem;colon wrote:Also another thing, I realised that I don't get any feedback from the player when I started it over the icon, by using the "Start MusicBee" function from the plugin it works..
The problem I do not know, for me it works. This requires clarification.
Re: MusicBee
Post by Sem;colon »
Pako wrote: Sem;colon wrote:-Repeat one Track
I didn't expect that.. very strange..
I can see in your musicbee webinterface, you seem to found some way to do it - how did you do it then?
Pako wrote: Sem;colon wrote:-Change Playing Track in the now playing list by index
It works.
well, partly... If you have two times the same file in the playlist it doesn't... It chooses always the first match.
Pako wrote:If this was the only obstacle for you, I can easily add it all to the plugin.
yes, that would be cool!
"Duration of now Playing list (total)": I know that the player calculate that anyway - isn't there an API possibility to get this data from the player? (just to save CPU Time)
Pako wrote: Sem;colon wrote:-Get Title of a track in the now playing list (not the trackTitle in file Tag but the one that the player shows!)
Sure, I have a lot of files without any tag information (old .mp3s and .wav) in that case the musicplayer (musicbee) just displays the filename without extension. This could be done be scripting using the URL and the Tag TrackTitle - but I think that's a bit error-prone and also creates maybe avoidable CPU load - it would be better to just get this info from the player (if possible)
Pako wrote: Sem;colon wrote:Also another thing, I realised that I don't get any feedback from the player when I started it over the icon, by using the "Start MusicBee" function from the plugin it works..
I did some more testing and found out, that this only happens if EventGhost runs as admin (win8) and MusicBee not.
So if I run both as admin it works, if I run both as user it works, also if I run EventGhost as user and MusicBee as Admin in works but if I run Eventghost as admin and MusicBee as user it doesn't... But I can still control the player, I just can't get information.
Re: MusicBee
Sem;colon wrote:I can see in your musicbee webinterface, you seem to found some way to do it - how did you do it then?
This is a little trick. I've waited a long time for the moment when someone asks for it ... :D
But it is very easy when you realize, that the web GUI always displays the current mode.
I did it so, that I clicked on the icon in the MusicBee window.
Sem;colon wrote:well, partly... If you have two times the same file in the playlist it doesn't... It chooses always the first match.
I do not have the possibility to do it better.
The only appropriate API function requires a URL as an argument.
Sem;colon wrote:Pako wrote: If this was the only obstacle for you, I can easily add it all to the plugin.
Well, try the new version, the files are attached.
New features (all in group Now playing list):
Get list of URL
Get tracks count
Get total duration
Get track title/file name
Notes:
1)To save the playlist, use the command Get list of URL and you still need a script or plugin File operations and action Write text to file, where Input text = {"\n".join(eg.result)}.
2)Command Get total duration is not available in the API. It is necessary to calculate the sum. The result is a little different, than shown in MusicBee GUI. This is probably due to the fact, that I have only rounded numbers available.
3)Command Get track title/file name is also not available in the API, but I created a substitute for it.
Sem;colon wrote:I did some more testing and found out, that this only happens if EventGhost runs as admin (win8) and MusicBee not.
I do not see any possibility to make some improvements.
BTW - MusicBee forum is again in operation.
MbEgPluginTestRelease.zip
(48.33 KiB) Downloaded 198 times
Re: MusicBee
I just released a new version of the plugin (0.0.9).
Changes:
  • New MusicBee API version taken into account.
  • Some bugfixes.
  • Added Get "Is running" action (with the possibility to stop the macro)
You can download it at the usual place.
Re: MusicBee
I'm slightly improved web interface (for new Tornado plugin).
In fact, I only added one button: Stop after current.
You can download the necessary files.
Tree_And_Www.zip
(175.21 KiB) Downloaded 187 times
radenblazed
Re: MusicBee
Post by radenblazed »
hay Pikofor some reason the album art wont load for internet explorer and firefox... it only seems to show in chrome
Re: MusicBee
ie does not support websockets and ff is not either (or in a specialized way) if you have an older version. I tried ff version 25.0 and websockets work fine.
This could eventually be the reason to the problems you experience
BR
Re: MusicBee
radenblazed wrote:hay Pikofor some reason the album art wont load for internet explorer and firefox... it only seems to show in chrome
I know, that each browser displays a page differently and that the best result gives Chrome (on the Android platform is the best UC Browser).
However, all major browsers works. Even also IE11 !
Maybe you do not have the latest versions.
Re: MusicBee
oops, I did not know that ie11 supports websockets...
lparedesl
Re: MusicBee
Post by lparedesl »
When I run the Playlist Command: Play Now... it always puts the songs in the same order. How can I play the playlist shuffled? One solution that occurred to me was to add a Shuffle List command to the Now playing list commands
Re: MusicBee
lparedesl wrote:When I run the Playlist Command: Play Now... it always puts the songs in the same order. How can I play the playlist shuffled? One solution that occurred to me was to add a Shuffle List command to the Now playing list commands
Yes, it is completely in your power.
Command Play is part of a macro.
Into the same macros you can add any other command.
Why not Set shuffle ON ? Best before (above) Play.
lparedesl
Re: MusicBee
Post by lparedesl »
Where is the Set shuffle ON command? I looked under Player command and Now playing list command and didn't find it.
Re: MusicBee
lparedesl wrote:Where is the Set shuffle ON command? I looked under Player command and Now playing list command and didn't find it.
lparedesl
Re: MusicBee
Post by lparedesl »
Thanks.. sorry I didn't find it before. But all that command does is turn on or off the shuffle icon at the bottom right. The playlist still starts with the same song as always and in the same order. When I double click the playlist in MusicBee it starts with a different song every time and the songs are in different order. I thought maybe the way I saved the playlist is in that order and that was why, because it is playing the file that I picked, but I went to the Playlists folder and played a playlist and it started with a different song and in different order.
Re: MusicBee
The new version (0.0.15) of the plugin is available.
Added actions Get output devices and Set output device.
