Thanks for the post! I am worried to try it tho. lol
Flyingsubs
Just tried it! Has so much promise and its causing one of my cores to be at 100%!
I no programmer, but it does seem like a step in the right direction. I could use it to be a remote control other than that, the LEAP was so disappointing.
LeapMotionGhost - Plugin for LeapMotion
Flyingsubs
Re: LeapMotionGhost - Plugin for LeapMotion
I think there was a 'classical' inside, I do not have a Leap, could you try this version?
BR Walter
BR Walter
Flyingsubs
I think that fixed it! Thanks!
I'll try it out and link it to arrow buttons and the enter key.
Flyingsubs
Flyingsubs
Thanks to User1306 and krambriw for the Leap Motion Controller plugin.
I have added it to the Remote Controls topic.
User1306 and Flyingsubs:
Some devices require a lot of unavoidable computation to work: e.g. the Leap Motion, Playstation Move, Xbox Kinect.
Other examples might be computer vision (like using Python with OpenCV) and, to a lesser extent, even voice recognition.
Thus, any plugin for those types of devices will eat up your CPU cycles to a certain extent.
The only way out of that, is to run them on a different machine on the LAN, and send the events to your dedicated HTPC via Network Event Sender/Receiver.
EventGhost 0.4.1.r1640
PHX01RN plugin v3.0.1
