I've got Suntracker, but it is not what I'm looking for. The sun is not really a variable in my switching, the day of week is... I know Suntracker can do that as well, but it gets complicated to use Suntracker without making use of sunsets.krambriw wrote:Search for "Scheduler"....or "SunTracker" in this forum if you would like to involve the sun status as condition
BestR Walter
Timer
Re: Timer
Re: Timer
I changed the Timer plugin to use EventGhost's internal scheduler.
Nothing has changed to the user but there should be less use of resources use and less potential for threading errors.
The old version also was imprecise as the processing time was taken account for the next interval (also this should be only milliseconds).
I would appreciate if some users could test the new version
http://www.eventghost.org/svn/trunk/plu ... _init__.py
Re: Timer
Hi Bartman,
I just renamed your new plugin to Timer2 to allow to have the old one as well
However, you have missed to insert revision information, therefore this crash
If you change line 5 to something similar like below it loads/compiles correctly
Next step will be some testing...
16:41:29 Error while loading plugin-file Timer2.
16:41:29 Traceback (most recent call last) (1016):
16:41:29 File "C:\Program Files\EventGhost\eg\Classes\PluginManager.py", line 178, in LoadPluginInfo
16:41:29 File "C:\Program Files\EventGhost\eg\Classes\PluginInfo.py", line 116, in ImportPlugin
16:41:29 File "C:\Program Files\EventGhost\plugins\Timer2\__init__.py", line 5, in <module>
16:41:29 IndexError: list index out of rangeIf you change line 5 to something similar like below it loads/compiles correctly
version = "1.0." + "$LastChangedRevision 000 $".split()[1],
Re: Timer
My current test has been running flawless over night since yesterday
Both timer types (your new (t1) and your old (t2)) triggering every 5th second
No problem detected. Stable memory usage. CPU load 0%
07:33:57 Timer.t110650 (10650, '2009-08-11 07:33:57')
07:34:00 Timer.t210633 (10633, '2009-08-11 07:34:00')
07:34:02 Timer.t110651 (10651, '2009-08-11 07:34:02')
07:34:05 Timer.t210634 (10634, '2009-08-11 07:34:05')
07:34:07 Timer.t110652 (10652, '2009-08-11 07:34:07')
07:34:10 Timer.t210635 (10635, '2009-08-11 07:34:10')
07:34:12 Timer.t110653 (10653, '2009-08-11 07:34:12')
07:34:15 Timer.t210636 (10636, '2009-08-11 07:34:15')
07:34:17 Timer.t110654 (10654, '2009-08-11 07:34:17')
07:34:20 Timer.t210637 (10637, '2009-08-11 07:34:20')
07:34:22 Timer.t110655 (10655, '2009-08-11 07:34:22')
07:34:25 Timer.t210638 (10638, '2009-08-11 07:34:25')
07:34:27 Timer.t110656 (10656, '2009-08-11 07:34:27')
07:34:30 Timer.t210639 (10639, '2009-08-11 07:34:30')
07:34:32 Timer.t110657 (10657, '2009-08-11 07:34:32')
07:34:35 Timer.t210640 (10640, '2009-08-11 07:34:35')
07:34:37 Timer.t110658 (10658, '2009-08-11 07:34:37')
07:34:40 Timer.t210641 (10641, '2009-08-11 07:34:40')
07:34:42 Timer.t110659 (10659, '2009-08-11 07:34:42')
07:34:45 Timer.t210642 (10642, '2009-08-11 07:34:45')
07:34:47 Timer.t110660 (10660, '2009-08-11 07:34:47')
07:34:50 Timer.t210643 (10643, '2009-08-11 07:34:50')
07:34:52 Timer.t110661 (10661, '2009-08-11 07:34:52')
07:34:55 Timer.t210644 (10644, '2009-08-11 07:34:55')My released plugins
Re: Timer
Still working without problem
LanceDrolet
Re: Timer
Is there a way to pass variables to the payload of the triggered event?
I'm trying to run a "convert-to-mpg" program when Vista Media Center records a show, but I have to wait until the show is done recording before converting it. So, I'm using directory watcher to see when a 'dvr-ms' file is created. I then want to wait a safe time and trigger an event that starts the converter. So, I have to pass the file location and destination to the event-handler (script) that runs the converter.
Is this possible?
Is this possible?
Re: Timer
I assume there will only be one file to convert at any given time. Could you store the file location into a fixed named/location file? The conversion program can then be triggered without any parameter, since it will always look in that file to find the information about the file to be converted.LanceDrolet wrote:Is there a way to pass variables to the payload of the triggered event?
Is this possible?
LanceDrolet
Re: Timer
No, there are many times when we record two or more TV shows at once (often with overlapping start/stop times). Otherwise, I'd just store the locations as eg.global variables.manjh wrote: I assume there will only be one file to convert at any given time. Could you store the file location into a fixed named/location file? The conversion program can then be triggered without any parameter, since it will always look in that file to find the information about the file to be converted.
LanceDrolet
Re: Timer
Ok, I figured out a work-around. I can embed the variables in event name.
in my case, it will be something like
Timer.inputFile;outputDest.convert
Then I just trigger the conversion with any "convert" event... then in the event-handler, parse the event.suffix to get at what I need. Quick and dirty, but it'll get the job done.
LanceDrolet
Re: Timer
Ok then... apparently, you can only use one timer at a time... Oh well, I guess I can just save the file info to a list in eg.globals and set a timer to run through the whole list in the middle of the night.
LanceDrolet
Re: Timer
Guess I misspoke... you are only allowed to use one instance of the each timer... as it says in the GUI..."Currently running timer with the same name will be aborted"...Bartman wrote:You can use as many timers as you like.
No worries, though... I found a solution to my problem.
Thanks.
