Dear Walter,
here is a modified version of the Tornado plugin.
Can you please try it?
In this case, similar errors ('WebSocket Protocol Error' and 'Masked frame from server') not occur?
Best regards,
Luboš
How To keep and recover websocket connections
Re: How To keep and recover websocket connections
- __init__.py
- Tornado plugin, version 0.6
- (125.75 KiB) Downloaded 163 times
Dear Pako, thank you
I will put in test very soon and both will run over night. So far the Webserver test is working fine.
I did not add any decoding/printout in the Tornado plugin for this, I did not know how to catch it
Correct, I have only seen this with the Tornado plugin (in javascript console):In this case, similar errors ('WebSocket Protocol Error' and 'Masked frame from server') not occur?
From javascript console: Invalid frame header
From javascript console: One or more reserved bits are on: reserved1 = 0, reserved2 = 1, reserved3 = 0
Dear Pako,
The test has worked fine during the night, I just would like to do some more tests during the day
Dear Pako,
During the day I have now performed what we maybe can call a "small stress test". I did connect several websocket clients to the websocket server (I think something like
- 5 clients i the same PC using Firefox
- 1 client using Chrome
- 2 tablets, android, each using Firefox
Result with Webserver:
1) Whatever I try, I get a lot of disconnects all the time when I start to use a more javascript heavy page. My browsers did reconnect but after not very long, disconnections came again and it started all over again and again
2) I have a feeling that a simpler html page will 'survive' longer, i.e the connection will live longer than if you have rather complex javascript code in the page (like I have)
3) I also had two crashes in the Webserver plugin and I just roughly changed the code in two places to be able to continue
At line 3764
Reason for the change was that I received an exception when deletion was tried on a client that was already deleted
At line 3764
Reason for the change was that it can happen that the client connection is already gone and if so the write_message will raise an exception
4) In my environment, with the web page I need, I could not find any solution to make it work without causing so many disconnects. I have no further ideas what could be improved/modified.
Result with Tornado:
1) The number of disconnects are very rare even if they do also happens
2) No further changes needed as I see it, the Tornado plugin is working fine
3) I have to use Tornado in my environment due to the fewer disconnects it creates
My best regards,
Walter
At line 3764
def BroadcastMessage(self, message):
tmp = list(self.wsClients.iteritems())
for key, client in tmp:
try:
client.write_message(message)
except Exception, exc:
if exc.args[0] in (10053, 10054, 10060):
try:
del self.wsClients[client]
del self.wsClientsTime[client]
eg.PrintNotice(self.text.forcDel % repr(client))
self.TriggerEvent(
self.text.wsClientDisconn,
payload = [client]
except:
pass
eg.PrintTraceback() # debugging ...
def write_message(self, message):
try:
self.request.send(chr(129))
length = len(message)
if length <= 125:
self.request.send(chr(length))
elif length >= 126 and length <= 65535:
self.request.send(chr(126))
self.request.send(pack(">H", length))
self.request.send(chr(127))
self.request.send(pack(">Q", length))
self.request.send(message)
except:
pass
My best regards,
Walter
Dear Walter!
Thank you for the tests and their detailed evaluation.
Described problems are probably not caused by new arrangements,
so nothing prevents use this version to the new EventGhost release.
Of course, I think including your recent changes.
Maybe someday we'll find the cause of this behavior and it will be possible to do better.
Best regards,
Luboš
Best regards,
Luboš
