Controlling EG from Amazon Echo
m19brandon
Re: Controlling EG from Amazon Echo
Post by m19brandon »
m19brandon wrote:I will double check but I believe they are open as I can hit the conf page and the Echo and find the bridge.
I opened an issue on the github project and they say the JVM is getting the 200 success code but erroring out on empty body or payload from the webserver. I need to play with it some more.
Thanks, B
I needed to add an index.html to the webserver folder. Now the body is not empty when JVM get a response. :D
m19brandon
Have been using the Echo bridge a lot, great work.
Any idea how to pass a spoke string to EG from the Echo vs turn on T.V.
I have EG setup to understand 100s of spoke phrases, this allows me to control the house from my android and I would like my Echo to do the same thing. Just need to pass a string. Ex Alexa, tell Home 'I want to watch ESPN'
sid007
Post by sid007 »
Thanks for this. This is great. I use the Alexa -> Hue Bridge Emulator -> EG -> Harmony to control my entertainment center.
Alexa turn TV on -> Projector, Receiver HDMI1, Comcast,
Alexa turn PS3 on -> PS3, Hdmi2
"" turn Chromecast -> Hdmi3
Alexa turn sound off -> Mute to receiver
Alexa turn sound on -> Mute to receiver (which unmutes it)
Alex turn fan on -> Programmed the fan remote as a new device in Harmony hub and it picked it up :D -> Power on, Oscillate, Medium Fan
Alexa turn everything off -> PS3 off, Receiver Off, Projector Off (has to send the off command twice b/c the projector is that way), Comcast off.
Alex -> Philip Lights works on via the real hue bridge
Time to think of more stuff to add and automate .. any suggestions? :!:
litfoo
Post by litfoo »
I have managed to add a device on the Hue Bridge emulator configurator page and it has been assigned with an ID, has a name and is labelled as a Switch
However, when I ask Alexa to discover my devices, it does not pick it up.
Anyone have any ideas as to why it is not picking it up?
thanks,
litfoo
***update - managed to get it working - had to used the full command C:\echo>java -jar amazon-echo-bridge-o.2.1.jar --upnp.config.address=xxx.xxx.x.80 **
xxx.xxx.x.80 is the IP of the machine running the jar
litfoo
Post by litfoo »
not sure how many people are using the EG > HarmonyHubControl
I am a little unsure as to the full path I should be using for HarmonyHubControl
At the moment my HarmonyHubControl.exe sits in C:\Echo\HarmonyHubControl
so i have entered C:\Echo\HarmonyHubControl\HarmonyHubControl.exe [email protected] mypassword 192.168.1.100 start_activity 1234567 but it does not work
I can get the commands to work if, from a command prompt, go directly into the folder and then run the .exe command with my email/password/ip etc combination
but can't get it to work from EG
Hope someone can help
Cheers,
litfoo
larrysmcfarlin
Post by larrysmcfarlin »
Ok, losing my mind lol...
Went through all the steps to get everything set up (Echo Bridge 0.1.3, latest EG). (1) HTPC in entertainment center is set as the bridge and has EG set up. (2) Desktop computer in office with EG set up.
Here's what I'm trying to do:
Echo hears the function and passes it to EG on the HTPC - I see it come into the log. I copy the entry from the log and added a macro that passes a payload to the Desktop (Send to another Eventghost function) which in turn sets the volume to a percentage value on the desktop.
Here's the issue:
When the event hits the HTPC, it doesn't trigger the macro. The echo passes the function to the bridge correctly, EG on the HTPC receives the command correctly - then it stops. If I execute the macro manually on the HTPC, it passes the payload to the desktop and completes the function correctly.
Notes: I set up "send to another Eventghost" function because if I passed it directly from the bridge to the desktop PC the payload would hit the desktop pc EG logs several times for some reason.
Any ideas?
m19brandon
Did you get your macro working on your HTPC.
Has the correct event been added to your HTPC. The one sent from the desktop computer?
bernd
Post by bernd »
Can someone say if the HA Bridge still works? I followed the instructions and created a new device that is showed in echo devise list. But when I say Alexa turn on "deviceXXX", I receive the answear: "the hub, connected with the device "deviceXXX" don't react, please check the network connection or power supply. But the devices or the java app is online. Anyone with the same issues?
Problem solved, I use another bridge:
https://github.com/bwssytems/ha-bridge
m19brandon
Yes for all the then. There are some key macros by default that u can copy from and change.
I am not sure of we can capture the address in chrome.
krysn95 wrote:Is it possible to make the next with EG:
If
a concrete webpage is opens in Chrome--> (http://www.example.com)
Than
mark the webpage text --> (simulate ctrl+a)
simulate a right mouse click to a defined place
simulate a left mouse click to a defined place
wait X seconds
close the concrete webpage --> (simulate alt+F4)
(really sorry if this question is lame, but I am totally beginner with this amazing app)
Thank you in advance for every help!
Jostein
Post by Jostein »
Hi.
I have got it working but alexa is responding: Sorry the device floor light is not responding........
I have used this: https://github.com/armzilla/amazon-echo-ha-bridge as bernd did.
when issuing a command the bridge sends a command to http://192.168.10.70:85/CMD?floorLight=ON witch results in an EG event as it is should.
Ha emulator shows:
2017-04-02 12:02:14.944  INFO 2152 --- [io-8080-exec-30] com.armzilla.ha.hue.HueMulator           : Making outbound call: GET http://192.168.10.70:85/CMD?floorLight=OFF HTTP/1.1
2017-04-02 12:02:15.002  INFO 2152 --- [io-8080-exec-30] com.armzilla.ha.hue.HueMulator           : GET on URL responded: 404
when i test using the ha bridge configurator i get the following message:
error http.png (5.07 KiB) Viewed 4954 times
Is there a way for eventghost to not show the 404 page? How are you solving this?
luma
Post by luma »
You need to drop an "index.html" file in the EG WebServer directory. It can be an empty file, but EG will respond with 404 if there's no default document there.
