trigger macro or event using keyboard shortcut?
Re: trigger macro or event using keyboard shortcut?
email plugin for eventghost
no need for batch files
will also send text messages
every cell phone carrier has something like this
(your phone number)@mms.att.net
send an email there and it comes through on your phone as a text
well for at&t neways
K
(148.3 KiB) Downloaded 115 times
Stalltime
Post by Stalltime »
Having to buy a hub [vera] is kind of disappointing. It is an extra expense and installation.
so if I choose a product like this, what would I be able to do with it without having a hub?:
http://www.zwaveproducts.com/shop/z-wav ... tin-nickel
Thanks kgshlosser for your input.
I was actually wrong. Event ghost "start application" can open URL shortcuts and email file extension [*.eml]. You're right. No need for batch files.
kkl
Post by kkl »
No. You need a Z-wave controller in order to operate a Z-wave device.
Stalltime wrote:Having to buy a hub [vera] is kind of disappointing. It is an extra expense and installation.
They're very reasonably priced, (about about a 1/5 of the price of a lock, where I am), and someone in your position could really get some use out of Z-Wave enabled gear. I know I do. Installation of the controller itself is just plugging in a power cord and net cable.
Have you heard of voxcommando? I haven't tried it, and unfortunately it's not free any more, but it seems a bit like Dragon, but geared more towards running things, rather than 'just typing', if you know what I mean. Dragon is pretty shitty for anything but dictation, as I'm sure you've discovered.
There's some good vids on YouTube for it: https://www.youtube.com/results?search_ ... oxcommando
