Possible to run 2 eventghost installations att the same time
Re: Possible to run 2 eventghost installations att the same
Also check my reply in the Tutorial section
tjabas
Post by tjabas »
krambriw wrote:Also check my reply in the Tutorial section
ok, thanks.
i changed the schedulghost to 1min and eggtimer to 5 mins, seems everything seems to work now.
and yes you can run 2 sessions of eventghost at the same time. i was mistaken.
you have to open a command window and navigate to the eventghost folder and run eventghost with the -multiload switch. this will allow multiple sessions of eventghost to run
i was looking at the code and saw that.
i apologize for the misinformation.
:-D
