Is just cause it is implemented that way, there is no obvious reason except that 1234 is rather common. I think it would not be hard to add but decision is up to the author Pako, there might be a reason behind his decision to not make it configurable.@krambriw, thanks for chiming in. i didn't know that websockets uses a fixed port. and why is that?
Controlling QLC+
Re: Controlling QLC+
- kgschlosser
oh ok. i didn't know if there was some kind of standard.
Jabberwock
It already is configurable, as I wrote above. I have used it with a 9999 port server.
- kgschlosser
ok. so are you good. or do you want me to do something with that osc protocol??
Jabberwock
Yes, I am good. OSC and/or ArtNet plugins might be useful in the future for someone, but I am quite satisfied with the web interface.
- kgschlosser
