Can't send keystrokes anymore? That tree is gone from the actions list...
And how come when I press the numlock button all key events change to "numlock.key", for example numlock.k? Anyway this was true in the pako version as well. And the numlock state randomly turns off by itself after some time. The keyboard plugin has some serious flaws.
New version 0.5.0-beta5 is out
Re: New version 0.5.0-beta5 is out
someguy1 wrote:Can't send keystrokes anymore? That tree is gone from the actions list...
Can you try with an empty config, only add the keyboard plugin and see if the events are still wrong?someguy1 wrote:And how come when I press the numlock button all key events change to "numlock.key", for example numlock.k? Anyway this was true in the pako version as well. And the numlock state randomly turns off by itself after some time. The keyboard plugin has some serious flaws.
Thx for showing me where to find the keystroke action.
I found out EG does that Numlock stuck thing if numlock is remapped in Autohotkey. Took care of that, but EG has a lot of problems with AHK.
Anyhow, if I assign a key as an event in EG keyboard plugin, and then whenever I use shift+that key it randomly gets stuck on Shift down, and I have to press shift again before I can use any key.
Nevermind I found an easier solution, I use the script by matejdro in this topic to send keys to Eventghost via AHK itself, and thus deleted the useless EG keyboard plugin.
viewtopic.php?f=9&t=6086&p=44419#p44419
