New version 0.5.0-rc1 is out
Re: New version 0.5.0-rc1 is out
ok sweet.. good deal..
I have also created a basic wrapper to handle the problems with wx.FlexGridSizer and wx.GridBagSizer
Tho I am sure it is going to need more work it is a basic start to eliminate those problems if you would like to run the code i can create a file you will need to add to EG and you will have to add one line to the core code if you would like to give it a test to see if it handles those problems for you
also.. you were correct about the having to run 2 plugin versions.. well you would have had to if i didn't create these wrappers. so this will eliminate need for that kind of craziness
Fine, but I'll prefer to wait with the core modifications. I think I fixed the wx stuff related to my plugins already when experimenting with earlier 0.5.0-beta's
BR Walter
ok cool. let me know if there is anything else that you are having an issue with. Water, you are one of the biggest plugin contributors. Your input is extremely wanted and needed. hopefully moving forward you will be on board with EG 0.5
I am doing my best to make EG better and also fix some outstanding bugs in it. I will mess up along the way but i need people like yourself to point me in the right direction.
Thanks a lot, so far the 0.5.0-rc1 is running fine, I have however not stressed it too much. But I also like and appreciate your great effort, is really very impressive. And sometimes I wonder if you are covering multiple time zones as well ;)
Anyway, in your hole 2'x2'x2' there is no dirt at all. It's a hole isn't it? A definition of a hole implies it is empty (as I have understood it I need to add)
And the color of the bear is white, it is a polar bear
Have a nice day/evening
Walter
dude... good job on the riddles.... thumbs up
