RFXtrx
Re: RFXtrx
No problem , I just wanted to encourage you. Try this script then:
#Broadcast RFXtrx events
newEvent = str(eg.event.suffix)
newPayload = str(eg.event.payload)
port = 33333
a = newPayload.split(':')
b = a[1]
c = b.split(' ')
d = str(c[1])
res = eg.plugins.BroadcastListener.Broadcast(
        d,
        'empty',
        port
It can be written more efficient but it gives you the idea,
jamesst
Re: RFXtrx
Post by jamesst »
Thanks Wlater :D
RichPyke
Re: RFXtrx
Post by RichPyke »
Hey,
I'm new to EventGhost, I used it about 6 months ago for some basic tasks but that was it. Now I have my RFXtrx I need to use it more. And so far it's been pretty easy going.
But, I have the OWL CM113 which is being picked up by the RFXtrx and using RFXmngr I get all the details from it;
0D590123E3002E001A0000000059
Packettype    = CURRENT
subtype       = ELEC1 - OWL CM113, Electrisave, cent-a-meter
Sequence nbr  = 35
ID            = 58112
Count         = 0
Channel 1     = 2.6 ampere
Channel 2     = 0 ampere
Channel 3     = 0 ampere
Signal level  = 5
Battery       = OK
But in event ghost I get
Unknown message: ['0d', '59', '01', '17', 'e3', '00', '2e', '00', '1d', '00', '00', '00', '00', '49']
I have had a look through previous posts in this thread and saw the ones about the OWL CM119/160 on page 5 from a few months back but I'm assuming these fixes which come from that don't cover the CM113?
Basically, how can I have event ghost read the message from the OWL CM113? Do I need to make any changes anywhere? Is it a case of an update to the plugin?
Apologies if I'm asking a stupid question here, I've literally only just started playing with event ghost and the RFXtrx.
RIch
Re: RFXtrx
Yes it is needed, I will look into it, it might not be too hard now when I have the details you provided.
BestR Walter
Re: RFXtrx
CM113 added, could you try it?
BestR Walter
(249.95 KiB) Downloaded 271 times
RichPyke
Re: RFXtrx
Post by RichPyke »
Thanks, that was fast!
I'll give it a try when I get home tonight and let you know what happens.
Edit.
Forgot I had Team Viewer installed... Just tried it and it works.
RFXtrx.Type: CM113 id: 58112 ' Counter: 46 Channel 1: 1.80 A Channel 2: 0.00 A Channel 3: 0.00 A signal: 5 battery: 9'
eddcole
Re: RFXtrx
Post by eddcole »
Hi could you please tell me how to control the HE105 via event ghost and this plug in. I can control it with the rfxmanager using the HE tab but it won't control with the AC codes. Any ideas please
Edd
Re: RFXtrx
Yes I can, it is not possible. There is no support implemented in the plugin for controlling HE105.
eddcole
Re: RFXtrx
Post by eddcole »
Thank you :(
Re: RFXtrx
In due time I will look into this. If I add it, would you be kind to try it and then report back your results?
BestR Walter
Pallantir
Re: RFXtrx
Post by Pallantir »
I get an error when activating X10 lighting, ARC and so on (I use ARC for motion detectors and a few other things). I don't know if it affects the performance of the plug-in. Here's the error code:
12:13:41   Error compiling script.
12:13:41   Traceback (most recent call last) (1568):
12:13:41     File "C:\Programfiler\EventGhost\eg\Classes\ActionItem.py", line 121, in SetArguments
12:13:41       self.compiled = self.executable.Compile(*args)
12:13:41     File "C:\Programfiler\EventGhost\plugins\EventGhost\PythonScript.py", line 71, in __init__
12:13:41       self.PrintTraceback()
12:13:41     File "C:\Programfiler\EventGhost\plugins\EventGhost\PythonScript.py", line 97, in PrintTraceback
12:13:41       treeItem.PrintError("Traceback (most recent call last):")
12:13:41   AttributeError: 'NoneType' object has no attribute 'PrintError'
Re: RFXtrx
Hi Pallantir,
I do not see any ref to the RFXtrx plugin in your error log. It seems you are running a script of some kind that causes the problem. Try to describe the steps I can follow to reproduce your problem.
BestR Walter
Pallantir
Re: RFXtrx
Post by Pallantir »
I see! Sorry, I don't know my ass from my elbow... :mrgreen: I have disabled everything here now, and I still get the error. Strange thing, earlier today it seemed to come and go with the X10 disabling and enabling. So then I have no idea what's wrong. I have no scripts that should cause this, even disabling everything in my setup. I have not messed with any files, but I will try to reinstall EventGhost, it may be something that's become garbled.
Edit: Installing the latest version didn't change anything. But it doesn't seem like it affects what actions I have, so I'll leave it for now.
DarkCinema
Re: RFXtrx
Post by DarkCinema »
Sorry for this NOOB question, I just ran into this RFXtrx433 module and would like to controll my "KlikaanKlikUit devices.
Is this possible with this plugin? What device do I select to controll "KlikAanKlikUit" devices with RFXtrx?
Re: RFXtrx
It should work with the ARC protocol
ARC protocol
ARC is the protocol used by different brands with units having code wheels A-P/1-16:
KlikAanKlikUit, NEXA, CHACON, HomeEasy, Proove, DomiaLite, InterTechno, AB600
