OpenNetHomeServer
Re: OpenNetHomeServer
This is great news anyway, now I can start tracking this problem !
Mastiff
Post by Mastiff »
Oh, btw, if it helps I can fix you access to my VM to play around. I'll just do a full backup of it first (so you can mess around all you want to without destroying anything), and then send you a TeamViewer link to play with. :mrgreen:
Mastiff
Post by Mastiff »
Or if I can do the testing just as easily as you program I will be on call with minutes reaction time to test new versions all day!
Just a few seconds left and you will have a new version, I have found the error...it was on my side
So this should work
(82.41 KiB) Downloaded 126 times
Mastiff
Post by Mastiff »
Great, man! :D
12:37:08      {'FineOffset|1150': 'Temp|12.5'}
Sounds about right? :mrgreen:
I still get these, though:
12:37:39   Error: <type 'exceptions.ValueError'>
Finally!
It was an embarrassing error on my side, I had defined dictionaries as self.monitor_fineoffset_mem = {} and self.decode_fineoffset_mem = {} but when I called them, I mistakenly used decode_fineOffset_mem and monitor_fineOffset_mem :oops:
The printed error you still get is correct, first time it is empty (but I will remove the print out in the final version that I will upload shortly to the normal place)
Is it still working ok? (maybe you need to wait 20 minutes to be sure)
Mastiff
Post by Mastiff »
How embarassing! I don't know how you made that error! :mrgreen: :mrgreen: :mrgreen: (Of course I would not know how you made it correct either...) It's been running for 45 minutes now, and no lost connection anywhere. I think this worked! Thanks, Walter! Great work!
Fantastic!
Thanks for your verification work, it was a bit tricky until we found it
I have now uploaded the official release
Mastiff
Post by Mastiff »
Brilliant, thanks! :mrgreen: I'll get that then. If you don't hear a very ugly scream from a western direction it works! :lol:
Mastiff
Post by Mastiff »
It worked at home, but when I put it in at the cabin this has happened during the night:
03:28:54            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75434, 75368)
03:31:55            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75483, 75434)
03:34:56            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75535, 75483)
03:37:57            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75586, 75535)
03:40:58            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75637, 75586)
03:44:00            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75690, 75637)
03:47:01            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75735, 75690)
03:50:02            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 75788, 75735)
And nothing else since it started. The icon in the tray was red, and I had to kill the process. Luckily it isn't all that cold there now, so no harm done, I hope.
There was no change that could cause that type of error. What has happened @ your cabin is that the plugin has failed in establishing a connection to NHS for receiving events. I can only recommend restart trials with this information provided.
Mastiff
Post by Mastiff »
I have restarted the system there, and we'll just see what happens. If anything. It may have been a fluke. Crossing fingers!
Mastiff
Post by Mastiff »
It happened last night again. :cry:
01:42:57   ClimateDataCalculation.vindstyrke 'Combo report created'
01:42:57   Exception in thread Thread-18694:
01:42:57   Traceback (most recent call last):
01:42:57     File "threading.pyc", line 532, in __bootstrap_inner
01:42:57     File "threading.pyc", line 484, in run
01:42:57     File "C:\Program Files (x86)\EventGhost\plugins\ClimaDataCalculation\__init__.py", line 2895, in CreateReport
01:42:57       rprtHeading
01:42:57     File "C:\Program Files (x86)\EventGhost\plugins\ClimaDataCalculation\CreateWindRoseHtml.py", line 24, in CreateWindRoseHtml
01:42:57       logstr += MakeWindRoseChart(rows)
01:42:57     File "C:\Program Files (x86)\EventGhost\plugins\ClimaDataCalculation\CreateWindRoseHtml.py", line 72, in MakeWindRoseChart
01:42:57       s_data[rdir][0] += 1
01:42:57   KeyError: ''
01:42:57
01:43:00   Tellstick.FineOffset|1195 'Temp|-16.6'
01:43:00   RFXtrx.Type: Viking 02811 id: 41216 ' temperature: +5.9 deg C signal: 6 battery: 9'
01:43:00      Loftet
01:43:00         Python Script
01:43:00         ClimateDataCalculation: TempDataCapture: Loftet
01:43:01   Current Q size:  15
01:43:03   RFXtrx.Type: THGN122/123, THGN132, THGR122/228/238/268 id: 62468 ' temperature: +12.7 deg C humidity: 34 %RH status: dry signal: 7 battery: 9'
01:43:03      Yttergangen (med fuktighet)
01:43:03         Python Script
01:43:03         ClimateDataCalculation: TempDataCapture: Yttergangen
01:43:21            No data found during specified range for Ute under hytta
01:43:21   OpenNetHome.'Lost contact with sensor: FineOffset|1276'
01:43:21   Tellstick.FineOffset|1159 'Temp|7.1'
01:43:21      Kj├©leskap
01:43:21         Python Script
01:43:21         ClimateDataCalculation: TempDataCapture: Kj├©lskapet
01:43:30   RFXtrx.Type: PCR800 id: 25856 ' rainrate: 0 mm/hr rainTotal: 269 mm signal: 6 battery: 100%'
01:43:30   RFXtrx.Type: THGN122/123, THGN132, THGR122/228/238/268 id: 29444 ' temperature: +6.5 deg C humidity: 39 %RH status: dry signal: 7 battery: 9'
01:43:30      Badet (med fuktighet)
01:43:30         Python Script
01:43:30         ClimateDataCalculation: TempDataCapture: Badet
01:45:01            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 104006, 103957)
01:48:02            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 104056, 104006)
01:51:03            ('OpenNetHome', 'Checking connection with...', 'Tellstick Duo', 104103, 104056)
I added the error from the CDC plug-in that happened a couple of minutes before this. I don't know if it's related. I will try a full restart of the VM, not just EG, to see if it happens again tomorrow night.
1) Where and how are you running NHS itself?
2) Have you checked the NHS log itself?
3) I run NHS in a RPi and the TCP port connection sometimes dies after a week or so. With the latest version, it stays alive longer
4) The error for CDC: wind sensor, are you expecting data from NHS for this?
5) Here we see a lost sensor event that I believe is correct?
6) I think the TCP port in NHS has died. Did you restart NHS yesterday?
