OK, I found an easy way to get the data. I can present both the condition, the temperature as well as the humidity. Humidity could also be good to know so that your marquees (or awnings) are not rolled out if the humidity is too high.
In what format would this be useful?
- a new actions that on request returns the complete set (condition, temp, humidity) in the payload
- update of the automatic event generated every minute with the complete set (as it is done today with condition only)
- keep the old event as is and in addition make a new one holding the temp and humidity
Anyway you will have to capture the data in a python script to make something useful with it but this I suppose is ok for you.
Reason for asking is that I am a bit afraid to break a backward compatibility if someone already uses the weather condition event that is generated every minute.
zaptorrent
Post by zaptorrent »
Cool! Maybe a new action with al the info would be best in order to keep it from breaking anything in other peoples setups.
For me personaly it'd work fine with anything where I then could do something like:
x = 7
if x > (int(eg.result)):
eg.TriggerEvent("It's below 7")
piert
Post by piert »
I agree with that in principle. Is it not possible to ask the user if they want to extend the 'standard one minute weather condition event' extended with additional information by adding a check box somewhere? If they do, the event is expanded, otherwise it stays the same.
Also, are more variables available from the weather service, such as wind speed and wind direction? These are also important variables for deciding if sunscreens need to be up or down.
Another 'nice to have' that I have been thinking about is weather forecast. Suppose you have an automatic garden watering scheme going and the weather service predicts a lot of rain tomorrow (while today is a day full of sunshine). It would be nice to automatically stop the watering today based on tomorrow's prediction.
It would also allow you to give yourself early weather warnings specific to your needs. As an example, if the predicted wind speed for the day after tomorrow, if it falls in the weekend, is above a certain threshold or from a certain direction, you need a warning to cancel or adjust a boat sailing trip.
Regards,
Perry
I could easily add a new action that holds all this type of weather condition data in the payload. Then with a python script, it would be very easy to extract exactly what is of interest. I will make a proposal that we could evaluate.
I have added 3 new actions that you can use in scripts. Below is the sample code that shows how it works. Each action returns a dictionary holding the corresponding data. Please try it out how it works for you.
(159.18 KiB) Downloaded 245 times
wind = eg.plugins.Suntracker.GetWindData()
print wind
{'direction': u'60', 'speed': u'11.27', 'chill': u'7'}
atmosphere = eg.plugins.Suntracker.GetAtmosphereData()
print atmosphere
{'pressure': u'1015.92', 'rising': u'0', 'visibility': u'9.99', 'humidity': u'93'}
forecasts = eg.plugins.Suntracker.GetForecasts()
print forecasts
[{'date': u'20 Oct 2012', 'high': u'9', 'code': u'11', 'low': u'8', 'text': u'Light Rain'}, {'date': u'21 Oct 2012', 'high': u'9', 'code': u'9', 'low': u'6', 'text': u'AM Drizzle'}]
print forecasts[0]
print forecasts[1]
piert
Post by piert »
This is working well, thanks. Would it be possible to get more than today and tomorrow's forecast? Five days would be ideal.
I found out other people are talking about this as well and there appear to be some solutions:
http://stackoverflow.com/questions/7399 ... eather-api
Hi Perry,
I tried the hint but for me it did not give any change. It still only provides forecasts for today and for tomorrow.
http://weather.yahooapis.com/forecastrs ... 29&u=c&d=5
only gives for today and tomorrow, not for 5 days as expected.
http://weather.yahoo.com/forecast/NLXX0023_c.html
however gives more days but I will have to look into this more, it gives more complex html parsing since it is not the recommended yahoo api function and therefore I am not sure if can be used for stability reasons (a small change on the yahoo html-page can cause the function to stop working).
Thanks anyway for the hint.
zaptorrent
This is great and i can get all the new data from these actions to use as I wish but I dont get where I find the current temperature? The data that's in the "condition" statement where you're getting the text (partly cloudy... aso) from? Am I missing something?
Missed one action, added in this version
(159.55 KiB) Downloaded 278 times
Use as follows:
condition = eg.plugins.Suntracker.GetCurrentCondition()
print condition
{'date': u'Sun, 21 Oct 2012 12:19 pm CEST', 'text': u'Mostly Cloudy', 'code': u'28', 'temp': u'9', 'title': u'Conditions for Stockholm, SE at 12:19 pm CEST'}
print condition['temp']
9
Will soon put this as a release version in the first first if everything seems to be working ok
zaptorrent
I havent tried everything but as far as I can tell it's working perfectly. Great job! :D
User1306
Post by User1306 »
I apologies if this question has been asked, but i looked through the forum and google and couldn't find help.
can someone please tell me how can i make Sun Tracker give me the weather condition with the temp and then have the speech plugin say the condition out loud?
i have my location set up fine, but i cant seem to know how to "Get" info from Sun Tracker.
This is a simple sample python script how you could do it:
weather = 'The current weather is '+condition['text']
temp = 'The temperature is '+condition['temp']+' degrees'
eg.plugins.Speech.TextToSpeech(u'Microsoft Anna - English (United States)', 0, weather, 0, 100)
eg.plugins.Speech.TextToSpeech(u'Microsoft Anna - English (United States)', 0, temp, 0, 100)
Samme
Post by Samme »
Hi Walter!
I updated the Suntracker today, then it broke!
15:13:41         Error starting plugin: SunTracker
15:13:41         Traceback (most recent call last) (1544):
15:13:41           File "C:\PROGRA~2\EVENTG~1\eg\Classes\PluginInstanceInfo.py", line 177, in Start
15:13:41             self.instance.__start__(*self.args)
15:13:41         TypeError: __start__() takes exactly 14 arguments (10 given)
Then I also get the following:
15:13:41      SunTracker: Start new or control running SunTracker
15:13:41         Plugin "SunTracker" is not activated
I grabbed the Suntracker from the first post and extracted it and overwrote the old files, maybe I should'nt have done that!
...so now what to do? Thankful for help, the sun is soon going down here in Gothenburg :wink:
User1306
Post by User1306 »
Thank you very very much for the quick response and the help.
sorry if this question is stupid, but to get the forecast for the day do i switch the Condition = .... to this forecasts = eg.plugins.Suntracker.GetForecasts()
thanks
@Samme, this might become problematic. It looks like it was a rather old version you had before?
One way you can try is this:
1) Disable the Suntracker plugin and all SunTracker actions so that they not try to start when EG starts
2) Save and exit EG
3) Restart EG (now the SunTracker plugin and the actions should not start)
4) Open the settings for the plugin, click ok (hopefully this works)
5) Do the same for all Suntracker actions
6) Save
If this worked, try to enable the SunTracker plugin. It should start. Do the same for each action. Check that they have started ok.
If this does not work, you can do some xml editing. Create a new EG configuration, add only Suntracker and configure one SunTracker macro/action. Save and exit. Now open both the old and the new xml files in a text editor
1) Copy paste the new section with the plugin part to the old xml
2) Study the format of the SunTracker actions in both files, try to repair the old ones so that they get the same number of parameters, use the same data, this can be changed later.
3) Save, restart EG, open the old xml, hopefully it will work
4) Open and verify the configuration of the plugin and it actions as described earlier above
If this does not work, a last resort is always to reconfigure everything from scratch.
But before doing this, post your EG configuration file here, I might be able to repair it for you if you do not succed.
