Changing focused application
Post by Bitmonster »
949 is up.
I hope I've fixed this bug.
kricker
Post by kricker »
Bitmonster wrote:949 is up.
Well, that bug was fixed, but now it's not picking up the different Task.Activated.xxx. For example clicking the mouse on the desktop does not get picked up as Task.Activated.Desktop. It only seems to catch Task.Created or Task.Destroyed.
950...
950 has the same bug... no need to install... I will have to take a deeper look...
False alarm... 950 seems to work...
kricker
Post by kricker »
Bitmonster wrote:False alarm... 950 seems to work...
...on my way then....
Well, 950 was also buggy. After some time the events weren't working any more. But 953 will do, I hope...
kricker
Post by kricker »
Bitmonster wrote:Well, 950 was also buggy. After some time the events weren't working any more. But 953 will do, I hope...
LOL...I just saw that and I am getting 953 now. BTW thanks for all the quick turn arounds.
BTW, if you want some quick feedback to save on posting busted versions feel free to IM me.
kricker
Post by kricker »
So far working like a dream. I wonder if it is working for aarb00?
aarb00
Post by aarb00 »
IÔÇÖll have to check it out. I stopped monitoring the thread frequently as I solved my problem with the script. If I can not use the script because programs are better logged that would be great. I will try and post my results when I can.
