Sapi.SpVoice
MonsterMagnet
Re: Sapi.SpVoice
Here attached is a new SpeechRecognition plugin.
I zipped the whole SpeechRecognition plugin as attachment.
It is based on the code in the thread above and with some extra modifications to make it work with current eventghost version (0.3.6.1487) and tested with Windows XP (Prof SP3) and to make them more userfriendly to use like the other components by adding plugins and configuring actions the usual way.
Feel free to modify further and improve if needed, but this works already and might want to be included in next release as new plugin.
PS 1: Speech SDK (f.e. v5.1) can be downloaded from MS here: http://www.microsoft.com/downloads/deta ... laylang=en
PS 2: I noticed one general error with the test function on the config panel of an action. If one has an existing action in the tree and configures the action (making modifications in config panel of action) and then press test button and then decides to still press cancel, it still is as if one pressed OK and the modified configuration used to test is taken over ( instead of return to orriginal config panel state before making changes, like one would usually expect from a cancel button)
PS 3: To use this Plugin: extract zip file and copy contents of zipfile into the Plugin Directory of EventGhost (normally under program files). Restart eventghost.
In Eventghost insert into the EG configuration tree the SpeechRecognition Plugin (not speech plugin).
Then add a macro with a SpeechRules action (available under SpeechRecognition folder in the new action dialog when SpeechRecognition plugin was added into tree)
Then Configure that new action to add the Words / EventNames you want it to recognise/generate (and test it or execute this action once to start recognition.)
Tip: Choose distinct Eventnames and easy to pronounce english single word eventnames to make it easy for the speechrecognition engine to recognise without mistakes.
NOTES ON CURRENT FUNCTIONALITY:
- Executing another SpeechRules action will end recognition of assigned words to any earlier executed SpeechRules action. (thus allowing to start listening for different keywords)
- Enabling or disabling the SpeechRecognition Plugin itself will Enable / Disable Speech recognition of any SpeechRules active at that time.
- Enabling or disabling the SpeechRules Action itself will actually not influence the processing of word recognition related to that Action. The SpeechRules Action needs to run once to start it's recognition and will actually keep recognising the assigned words till a different SpeechRules action is executed. (or till Plugin is disabled) ( ==> The enabling or disabling of these SpeechRules actions will ofcourse cause the SpeechRules action itself to execute or not, thus potentially allowing to redefine or not the words being recognised)
- Once the SpeechRecognition engine detects in your voice one of the eventnames/words configured in the last executed Speechrules action, it will trigger automatically that matching word as EventGhost event. (pay attention to lowercase/uppercase when adding words to recognise in the voice input as events in the SpeechRule action configuration, since it will generate the event/word exactly as typed in that Configuration Panel)
Note: if plugin doesn't work: Ensure the correct Speech SDK for your OS/platform is installed already, if you have other SDK version or other operating system then XP, the delivered generated voice.py file needs potential replace, and can be regenerated with PythonWin (f.e. run COM makepy utility on Microsoft Speech Object Library 5.1 and rename resulting file as voice.py and put in the SpeechRecognition Plugin folder) as described in earlier link somewhere in this thread. (The current attached voice.py is generated with Microsoft Speech Object Library 5.0)
PS 4: Use Control Panel -> Speech -> tab: Speech Recognition to configure engine and microphone level and also to train the engine with your voice to further improve recognition results.
PS 5: Reattached initial zip file again to add Translation Support and also cleaned up earlier wrong class hierarchy
PS 6: Added SampleSpeechRecognition.xml EventGhost configuration file with some speechrecognition added on top of the usual Example.xml file (for some commands only yet)
PS 7: UPDATED FILE AGAIN ON 2-1-2009:
1) to add support for a python script to get the current list of recognised words (through an extra Commands getter function, returning list of currently known commands which is now added on the action)
2) to remove functionality to set speechrecognition when pressing OK on the configuration dialog, instead the action must be executed once to become active instead of only configured.
3) updated demo file to show how to let the PC speak the currently known commands in return to asking for "help".
PS 8 : ATTACHED SPEECHRECOGNITION ZIP FILE IS OUTDATED AND DOES NOT WORK WITH LATEST EVENTGHOST VERSION, PLEASE SEE MY LATER POST FOR NEWEST WORKING VERSION
You do not have the required permissions to view the files attached to this post.
Re: Sapi.SpVoice
Thank youfor this great plugin Peter. What do you think of the performances of you plugin compared to GlovePIE or Shoot 1.6.4 ?
Re: Sapi.SpVoice
i have windows XP and have SAPI 5.1 --- so i do not need to regenerate the file if im running xp ?
how would i go about doing this where is the COM makeup utility, and do u mean rewrite the code or regenerate? {what version of PythonWin would you recommend for this to make it simple}
i am having problems getting it to work it will work for a minute or so then stop working all together, then about a few minutes later it will show a load of commands from speech recognition plugin.
please help i would appreciate it very much thank you in advance!!
specter333
Re: Sapi.SpVoice
I get this error message when I open EG. I downloaded the latest plugin, have the latest version of EG and have XP Pro SP3 with all available updates. Any ideas? Thanks
Traceback (most recent call last) (1076):
File "C:\Program Files\EventGhost\eg\Classes\PluginInfo.py", line 288, in CreatePluginInstance
File "C:\Program Files\EventGhost\plugins\SpeechRecognition\__init__.py", line 71, in __init__
File "C:\Program Files\EventGhost\plugins\SpeechRecognition\voice.py", line 2470, in CreateRecoContext
File "win32com\client\__init__.pyc", line 94, in Dispatch
AssertionError: this is deprecated and will go away- Bitmonster
Re: Sapi.SpVoice
Open __init__.py and search the line:and delete it. Then delete the file voice.py and try it again.
import voicePlease post software-related questions in the forum - PMs will only be answered, if really private, thanks!
specter333
Re: Sapi.SpVoice
Now I get this error,
And it also gets,
I'm using the version dowloaded from Peter's post earlier in this thread, PS 7: UPDATED FILE AGAIN ON 2-1-2009: Is this the correct one for use with EG3.7.r1076? Also using XP Pro SP3 with all updates.
Error while loading plugin-file SpeechRecognition.
File "C:\Program Files\EventGhost\eg\Classes\PluginInfo.py", line 126, in ImportPlugin
File "C:\Program Files\EventGhost\plugins\SpeechRecognition\__init__.py", line 171, in <module>
TypeError: Error when calling the metaclass bases
cannot create 'NoneType' instances
C:\Program Files\EventGhost\eg\Classes\PluginInfo.py:293: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6And it also gets,
Plugin: SpeechRecognition #on
Error starting plugin: SpeechRecognition
Plugin load error!Thanks
Chaemelion
Re: Sapi.SpVoice
I don't know if anyone mentioned (I didnt bother to translate the last two pages) but someone mentioned looking for a german voice? A German voice (and many other good ones) can be found on the Cepstral website. The demo voices work, but inject registration notices into the text spoken. You can buy the voices for like $30 I believe someone said it was, or you could use the key generator >_>
Re: Sapi.SpVoice
Installing the Microsoft Speech SDK
The Microsoft Speech SDK is a free download from http://microsoft.com/speech/.
After installing it, use the MakePy utility to produce a Python stub for the COM object (in PythonWin, select Tools | COM MakePy utility | Microsoft Speech Object Library 5.1).
(I installed, used and tested with Microsoft Speech Object Library 5.0 )
Rename resulting file as voice.py and put in the SpeechRecognition Plugin folder
PS: Python and Pythonwin can be gotten here :
http://www.python.org/download/windows/
http://sourceforge.net/projects/pywin32/files/
(I used orriginally python version 2.5.2 and now 2.6.2)
Re: Sapi.SpVoice
Keywords: voice recognition, speech recognition, voice commands, speech commands, speech to event, voice to event, speech interpretation, voice interpretation
The earlier voice.py file was created with python 2.5.2 and does not work anymore if using eventghost version 0.3.7 r1194. To solve the compatibility issues with voice.py and this new eventghost version, I regenerated the voice.py with python 2.6.2 and this makes it work again. Please delete the voice.pyc and replace the voice.py file in the earlier package with attached version and it works again when using the latest eventghost build available for download (as of this postingdate).
Note: this voice.py file is still generated from the Microsoft Speech Object Library (5.0) for windows xp
Have attached in this post the latest FULL SpeechRecognition plugin version as a zip file.
Re: Sapi.SpVoice
First of all thanks for the Speech Recognition pulgin, just starting to use this myself.
From my experience so far, the recognition works well but it would be great if i could disable the Windows default commands and just use those created within EventGhost?
I have tried to search web regarding this, but the solution sounds way to involved for me to do anything with.
This is what i have found so far....
You need to use an InProc version of speech recognition, which gives you a private recognizer.
Bad:
hr = pRecognizerEngine.CoCreateInstance( CLSID_SpSharedRecognizer ); // Shared, gives Windows the chance to recognise commands.
Good:
hr = pRecognizerEngine.CoCreateInstance( CLSID_SpInprocRecognizer ); // Private, does NOT allow Windows to process commands.
You'll have to do a lot more calls to set up the Audio Input, and manually activte the recognizer, but it will allow you to use your grammar without having to put up with Windows trying to 'help' you.
Two important lines you'll need to use before anything will happen:
hr = pNavGrammar->SetGrammarState(SPGS_ENABLED);
hr = pNavGrammar->SetDictationState(SPRS_ACTIVE);
Is this at all possible with EventGhost Speech recognition plugin, or is there any easier way to disable the windows recognition commands?
Regards, J
Bad:
Good:
Regards, J
