Just as an FIY, I had this identical problem. And the solution was to add a timer of 30 secs, but also I had to plug my firefly receiver directly into a usb 1.0 port. I went into my bios and changed the settings to autodetect the speed of a connected device, and that did the trick.
Hope this helps anyone else struggling with the same problem
- cguy
EventGhost + Snapstream Firefly = disabled @ startup!
Re: EventGhost + Snapstream Firefly = disabled @ startup!
I'm glad to hear I'm not the only one going through it (sev's not going crazy.cguy123 wrote:Just as an FIY, I had this identical problem. And the solution was to add a timer of 30 secs, but also I had to plug my firefly receiver directly into a usb 1.0 port. I went into my bios and changed the settings to autodetect the speed of a connected device, and that did the trick.
- cguy
PS: If you have any problems with lag between hitting buttons, let me know. I replaced the Snapstream (snapstream.exe's) DLL with the X10generic drivers and it works perfectly now!
