Timer
Re: Timer
Timer is a great plug-in.
However, I noticed that it creates all the missed events according to the set interval when the system resumes from Standby.
Example:
Timer is set to 60 seconds using unlimited intervals (e.g. a simple clock timer).
System suspends on 06:00 PM.
System resumes on 07:00 PM the same day.
-> before System.Resume is triggered all missed 60 timer events (1 h time difference) are triggered before.
One can imagine what this can lead to if you have your PC resume from beeing in standby for a week or so.
My current fix is to abort the timer on the System.Suspend event and reinitialize it on System.Resume, which works just fine.
I would not call this a faulty behaviour and maybe it has been implemented intentionally but what about adding a checkbox to let the user choose how the timer plugin should behave in case of a resume from standby?
Thanks.
Example:
Thanks.
Re: Timer
I've held off for a long time, but now that I'm revisiting this, I just can't seem to make time work for me.
Is there a doc somewhere to check out?
Here's what I'm trying to do. I want to use Timer to trigger a LibrayUpdate macro once per day.
I have a timer set to go off at 2am each day with an event name of "Timer.UpdateVid"
I then have a macro that contains the event Timer.UpdateVid along with the XMBC action to Update the video library.
It looks something like below, but when I hit 'test' the only thing I see in my log is the Timer event. No trigger.
Fail.
Can anyone get me on track and show me the error of my ways?
Fail.
- <EventGhost Name="Configuration Tree" Expanded="True" Version="1262" Guid="{E0798B74-3CB2-4AB7-9778-E6323F14FE04}" Time="1261411792.77">
- <Autostart Name="Autostart" Expanded="True">
<Plugin File="XBMC" Identifier="XBMC">gAIpLg==</Plugin>
<Plugin File="Timer" Identifier="Timer">gAIpLg==</Plugin>
<Action>Timer.TimerAction(u'Update_Vid_Lib', 0, 0, 86400.0, u'Timer.UpdateVid', False, True, 2, u'02:00:00')</Action>
</Autostart>
- <Folder Name="XBMC" Expanded="True">
- <Macro Name="Update Video Library" Expanded="True">
<Event Name="Timer.UpdateVid" />
<Action>XBMC.UpdateVideoLibrary()</Action>
</EventGhost>Re: Timer
should be
<Action>Timer.TimerAction(u'Update_Vid_Lib', 0, 0, 86400.0, u'UpdateVid', False, True, 2, u'02:00:00')</Action>
otherwise the fired event would be 'Timer.Timer.UpdateVid'.
Regards
Prinz
should be
Regards
Prinz
Mein HTPC:
CPU: Intel E5200
OS: WinXP SP3
CPU: Intel E5200
OS: WinXP SP3
Re: Timer
Ahhh-
Thank you very much.
Presently the 'Test' button does not fire off the Event in 'Event name:', the only thing that shows up in the log is Timer: Start new...
It would be helpful if 'Test' also fired the Timer.whatever event to actually test the trigger.
I'm in business though. Appreciate the assistance.
Re: Timer
Hi!
How can i get current timer status (time remaining) from specified timer using "Phyton command" or "Python Script"? I want to use this value in "Show OSD".
On Russian:
ðƒð¥ð┤Ðüð║ð░ðÂð©ÐéðÁ, ð║ð░ð║ ð╝ð¥ðÂð¢ð¥ ð┐ð¥ð╗ÐâÐçð©ÐéÐî ÐéðÁð║ÐâÐëðÁðÁ Ðüð¥ÐüÐéð¥ÐÅð¢ð©ðÁ ð¥ð┐ÐÇðÁð┤ðÁð╗ðÁð¢ð¢ð¥ð│ð¥ Ðéð░ð╣ð╝ðÁÐÇð░ (ð¥ÐüÐéð░ð▓ÐêðÁðÁÐüÐÅ ð▓ÐÇðÁð╝ÐÅ) ð©Ðüð┐ð¥ð╗ÐîðÀÐâÐÅ "Phyton command" ð©ð╗ð© "Python Script"? ð£ð¢ðÁ ð¢ÐâðÂð¢ð¥ ðÁð│ð¥ ð¥Ðéð¥ð▒ÐÇð░ðÀð©ÐéÐî ð©Ðüð┐ð¥ð╗ÐîðÀÐâÐÅ "Show OSD".
On Russian:
Re: Timer
Hi guys i'm trying to use timer to set an alarm to wake up. I want to open mediamonkey and turn on the stereo. So my marco it's ready to do this but I don't succed to set the timer... I've put it in the wake up macro but it don't work... How I can make it go? There's a guide somewhere to use timer? O someone can explain how to use that.. Thank you bye bye
Re: Timer
Can u be more long in your answer pls? Via timer in autostart? How i have to set this timer to start a macro? How? What's the order to set macro timer event and so on? How I've to use trigger to use timer? Trigger make me only set an event and not a macro! It ask me event name...
<EventGhost Version="1387">
<Macro Name="Timer Sveglia" Expanded="True">
Timer.TimerAction(u'Sveglia', 0, 0, 1.0, u'', False, True, 2, u'11:30:00')
MediaMonkey.Start()
EventGhost.Wait(5.0)
MediaMonkey.LoadPlaylist(u'Macchina', 1, 1, 1, True)
MediaMonkey.Play()
<Action Name="USB-UIRT: Transmit IR Accendi Stereo">
USB_UIRT.TransmitIR(u'0000 006D 0000 0032 0083 0042 0011 0010 0010 0032 0010 0011 0010 0011 0010 0011 0011 0011 0010 0011 0010 0011 0010 0010 0011 0011 0011 0011 0010 0011 0010 0011 0010 0031 0011 0010 0011 0010 0010 0011 0010 0011 0010 0010 0011 0010 0011 0010 0010 0032 0010 0011 0010 0032 0010 0010 0011 0011 0011 0031 0010 0032 0010 0032 0010 0011 0010 0010 0011 0010 0011 0031 0011 0010 0010 0032 0010 0032 0010 0032 0010 0032 0010 0010 0011 0010 0011 0031 0011 0010 0010 0011 0010 0010 0011 0010 0011 0011 0010 0011 0010 0032 0010 0AEC', 4, 0)
EventGhost.Wait(10.0)
<Action Name="USB-UIRT: Transmit IR Volume -">
USB_UIRT.TransmitIR(u'0000 006D 0000 0032 0083 0043 0011 0011 0011 0032 0011 0011 0010 0011 0010 0011 0011 0011 0011 0011 0010 0011 0010 0011 0010 0011 0011 0011 0011 0010 0010 0011 0010 0032 0010 0011 0011 0011 0011 0010 0010 0011 0010 0011 0010 0011 0011 0011 0010 0032 0010 0011 0010 0032 0010 0011 0010 0011 0011 0010 0010 0011 0010 0011 0010 0011 0011 0011 0011 0011 0010 0032 0010 0011 0010 0011 0011 0011 0011 0011 0010 0032 0010 0011 0010 0011 0010 0032 0011 0011 0011 0010 0010 0011 0010 0011 0010 0011 0011 0011 0011 0032 0010 0AF8', 4, 0)
<Action Name="USB-UIRT: Transmit IR Ingresso Aux">
USB_UIRT.TransmitIR(u'0000 006D 0000 0032 0083 0042 0011 0010 0011 0031 0010 0011 0010 0011 0010 0011 0011 0010 0011 0010 0010 0011 0010 0011 0010 0010 0011 0010 0011 0010 0010 0011 0010 0032 0010 0011 0011 0010 0011 0010 0010 0011 0010 0011 0010 0010 0011 0010 0010 0032 0010 0011 0010 0032 0010 0011 0011 0010 0011 0010 0010 0011 0010 0011 0010 0011 0011 0010 0011 0010 0010 0011 0010 0032 0010 0032 0010 0010 0011 0010 0011 0010 0010 0011 0010 0032 0010 0011 0011 0031 0011 0031 0011 0010 0010 0011 0010 0032 0010 0011 0010 0010 0011 0AF2', 4, 0)
<Action Name="USB-UIRT: Transmit IR Volume +">
USB_UIRT.TransmitIR(u'0000 006D 0000 0032 0084 0043 0011 0011 0010 0033 0010 0011 0010 0010 0011 0010 0011 0011 0010 0011 0010 0011 0010 0011 0011 0011 0011 0011 0010 0011 0010 0011 0010 0032 0011 0010 0011 0011 0010 0011 0010 0011 0010 0010 0011 0011 0011 0011 0010 0033 0010 0011 0010 0032 0010 0010 0011 0011 0010 0012 0010 0011 0010 0010 0011 0010 0011 0011 0010 0011 0010 0011 0010 0010 0011 0011 0011 0011 0010 0011 0010 0032 0010 0010 0011 0011 0011 0011 0010 0011 0010 0011 0010 0010 0011 0011 0010 0011 0010 0011 0010 0032 0010 0AF4', 4, 0)
This is my macro for wake up... Now like this it don't go... Where i need to put the timer? And were the trigger if i need it... And what's the event string requested in the trigger? Thank you
MediaMonkey.Start()
MediaMonkey.Play()
Re: Timer
Actually anything in EG ist driven by events. You could open the EventGhost window and launch a macro manually but that is not practically for every day use.
You need at least one event that launches a macro starting the timer.
Re: Timer
So i need to put in the wake up macro first the event and then the timer and then all the rest? And there isn't a way to set a macro start without any event? I need to repeat the waku up macro every morning... I need every time to push the key I've linked to macro? And if i push the key and then restart the pc when pc wake up it don't restart the timer right? My pc start automatically in the morning
Re: Timer
You don't need any timer action in the wake up action. Just assign FROM the timer plugin.
You could use the wake up macro to set up a new timer or let the timer repeat itself after 24 hours but for long timed periods you might be better off triggering an event with the windows task scheduler and use the command line parameter.
Re: Timer
I had double clicked on timer plugin and it don't show me any timer... Where i can add a timer to let it display it? Or what's the command line parameter to use with windows scheduler? And were I need to put it? Sorry but i don't really understand and i can't find a guide or other for that! Thank you for your help
