Library: AudioEndpointControl
topix
Re: Library: AudioEndpointControl
Post by topix »
Sem;colon wrote:with my modification of the system plugin,
Where do i find this modified plugin? Or if didn't released it here, can you send it to me please?
topix wrote:Where do i find this modified plugin? Or if didn't released it here, can you send it to me please?
Here
topix
Post by topix »
aah, thanks. I thought that is the AudioEndPoint plugin. :oops: :oops:
In the next days i will test and integrate it.
Sem;colon wrote:.GetMute() returns an integer, not a boolean while .SetMute() needs Boolean. Otherwise I would have never done the "==1" stuff in the first place. But I changed it to this now:
Could you show me an example/situation for when .SetMute() has a problem with a non Boolean arg? I use both a 0 (zero) and 1 and there is no problem.
Post by Sem;colon »
hmm, no, sorry, I can't reproduce it any more (don't know what I did back then, but I remember getting an error or at least it wasn't working...)
Well, if integer is the way to go, I'm fine, I can change the plugin, but then I'd ask you to change OnNotify Notify.Muted to integer as well, for consistency, as this is Boolean.
Sem;colon wrote:hmm, no, sorry, I can't reproduce it any more (don't know what I did back then, but I remember getting an error or at least it wasn't working...)
OK
Apparently I typecast the result to Boolean, so I can remove that.
The interesting thing is that the Windows API documentation declares it to be a Boolean and the comtypes API interface definition declares it as a Boolean but it still comes out as Integer, so it might be a bug in the comtypes library and might change in a later version.
So the question should we keep it as an integer that the API gives us or change it to Boolean? I kinda like it to be a Boolean as it seems more clear that Mute is True or False.
Post by Sem;colon »
jonib wrote:So the question should we keep it as an integer that the API gives us or change it to Boolean? I kinda like it to be a Boolean as it seems more clear that Mute is True or False.
I agree, but if the system default is int somehow, so that's OK for me as well. It should just be consistent.
So, from my point, whatever you prefer! :)
Sem;colon wrote:I agree, but if the system default is int somehow, so that's OK for me as well. It should just be consistent.
So it's defined as Boolean everywhere, I like it to Boolean so I'll make it Boolean, thanks for the input.
I'll try to fix the library based on the modifications done by topic2k today, so it can be used in EventGhost.
