TellStick Duo
Mastiff
Re: TellStick Duo
Post by Mastiff »
Wow, I didn't get a mail about this, so I didn't know you had answered. Sorry. As for the first part, yeah, that's how it works now.
I'm running it in the same VM, and I guess I can probably close it and restart it with a command line thingy, I was just thinking that maybe there's a built-in command that can be sent on the tcp command port that could restart it. Or maybe not?
Re: TellStick Duo
No there is not, and not on the REST interface either...maybe a good suggestion to Stefan :D
Mastiff
Re: TellStick Duo
Post by Mastiff »
Yep, it would be! I'm guessing you mean that I should suggest it, right? :roll: Dump it on the new guy, huh... :lol:
Re: TellStick Duo
Re: TellStick Duo
Mastiff wrote:Very interesting, thanks! :D Sounds like a nice, general feature to me, so maybe Pako will take the bait? :lol:
Log redirector and filter
Mastiff
Re: TellStick Duo
Post by Mastiff »
Nice! Thanks, Pako! :D
Mastiff
Re: TellStick Duo
Post by Mastiff »
Krambriw, I keep getting this event in the log without doing anything for it:
10:03:18   OpenNetHome.RollerTrolBlind is 14393
Any idea what that is? It seems to be the house code, but there is nothing going on with any RollerTrol switches in the cabin.
Re: TellStick Duo
I think I fixed that in the latest version, are you using version = "1.1.7b9" ?
And the reason why was because Stefan did put the RollerTrol as 'Hardware' (and I am monitoring 'Hardware' for connection problems...)
So to get things correctly, use also Stefan latest and check that your RollerTrols are all cathegorized as 'Actuators'
Mastiff
Re: TellStick Duo
Post by Mastiff »
Aha, thanks! Then it's not a problem. I'll fix that next time I get to the cabin. :)
Filandre
Re: TellStick Duo
Post by Filandre »
I made some update to the TellstickDuo plugin to get the state of a device (new class State), which simply return the state on/off or the dim value in eg.result.
It's useful for me, and I can share the source for anyone. Can I put it on this thread?
Regards,
Filandre
Re: TellStick Duo
Thats good!
You can put your modified version here in the thread, yes, but provided you made your changes on the latest version...otherwise I have to ask you to do so first
Once done, I will continue from this version
Filandre
Re: TellStick Duo
Post by Filandre »
The last version was 2015-02-13.
I added the class "State" in this version. It's now an April Fools version!
No, no, it works!
Regards,
Filandre
__init__20150401.py
(91.63 KiB) Downloaded 143 times
Re: TellStick Duo
Fine, I will 'inherit' your version, thanks for your work
BestR
Mastiff
Re: TellStick Duo
Post by Mastiff »
Removed, moved to correct plug-in, sorry about that...
Filandre
Re: TellStick Duo
Post by Filandre »
You can simply do this with a timer:
<Macro Name="Detect TellStickDuo time-out">
  <Event Name="TellStickDuo.*" />
      Timer.TimerAction(u'TellStickDuo', 0, 0, 120.0, u'TellStickDuo time-out', False, False, 1, u'00:00:00')
<Macro Name="TellStickDuo time-out">
  <Event Name="Timer.TellStickDuo time-out" />
  ...any action to signal a problem...
