RFXtrx
alonmalka
Re: RFXtrx
Post by alonmalka »
Great!! Now it works!!
Thanks alot.
I will keep you up to date if there is any other ussue with the two Rfxtrx Config
BR
Alon
Re: RFXtrx
New version released in the first post
- Made event prefix configurable (to support multiple RFXtrx devices)
- Added action to dim AC devices up/down in defined step size
- Saving the dim level persistent
Re: RFXtrx
- supporting firmware up to ver 73
Re: RFXtrx
- supporting firmware up to ver 74
Jakov
Re: RFXtrx
Post by Jakov »
I have purchased a couple of Livolo switches, and they work as expected ( no just ON command) , except that the dimmer switch doesnt respond to dim+ and dim- commands. Toggle on/off and all-off work.
The dim commands don't work form rfxmng as well.
Has anyone else this problem?
mbaan76
Re: RFXtrx
Post by mbaan76 »
I'm using your plugin for a long time and i'm very happy with it. I have a questions about about the Oregon WGR800 Wind speed and direction meter. If i receive the signal in the RFXCOM manager i see speed values the following format: 1,9 (with one decimal). When i receive the signal in eventghost there are no decimals. just showing 1, or 2 or 3 etc etc. I'm writing this signal in my Msql database and i like to store it with one decimal.
Is this something i can change any ware, or is this just the plugin limitation?
Kind regards,
Marco
Re: RFXtrx
Marco,
You have found a bug, I made a mistake in the decoding/calculation...
I am curretly working on a new version I will release beginning next week and I will include a fix for this error as well.
Best regards & thanks, Walter
Re: RFXtrx
@Marco,
I think I fixed it already, could you verify if it is ok?
(Just replace with the file below & restart EG)
BR
(502.85 KiB) Downloaded 186 times
mbaan76
Re: RFXtrx
Post by mbaan76 »
Dear Walter,
It works! :D
I now see the decimal. Thank you very much for this fast service.
Marco
Re: RFXtrx
Re: RFXtrx
Added action to support RFY (SOMFY Compatibel) Venetian blinds, new version in first post
Re: RFXtrx
New version released in first post. Long time wanted support for potential free 12V and 220V relays added, Lighting5 ÔÇô Aoke relay.
The Aoke 12V DC - 315MHz or 433.92MHz 1 channel relay is available at http://www.aliexpress.com store No.110758.
Indicate clearly the required frequency when ordering!
The 1 channel learning relays can be used, see the picture below.
For example, for 1 relay order:
http://www.aliexpress.com/store/product ... 34863.html
or for 6 relays:
http://www.aliexpress.com/store/product ... 06574.html
The jumper next to the learning button defines to operating mode:
Open = momentary
1-2 = toggle mode
2-3 = on/off mode (to be used with the RFXtrx)
A 220V version is also available:
For orders:
http://www.aliexpress.com/store/product ... 68101.html
husa550
Re: RFXtrx
Post by husa550 »
Hi
Im using the RFXtrx plugin to switch on/off several Nexa switches and that work perfect!
Now i got a temp sensor that the RFXtrx detects and recieve data from.
How do i send this data to my comandfusion/iviewer config?
This is how it looks in EG:
RFXtrx.Type: Rubicson id: 513 ' temperature: +17.4 deg C humidity: 77 %RH status: wet signal: 6 battery: 9'
It would be nice to send this data to my iPad and see it in iViewer!
I use the Commandfusion plugin to control XBMC and other stuff on a cumputer.
Thank's!
Re: RFXtrx
Hello, it should not be too difficult, you can use the CommandFusion action 'Serial Change'
A sample python script that you can put in a macro that gets triggered by the RFXtrx (Rubicson) event looks like the below. You have to edit and insert the correct 'join' number in the SerialChange command.
BR Walter
pload = eg.event.payload
m = pload.split(' ')
temperature = str(m[2])
#print temperature
try:
    eg.plugins.CommandFusion.SerialChange(1, temperature)
except:
    print 'Detected problems sending to CommandFusion'
husa550
Re: RFXtrx
Post by husa550 »
Hi Krambriw!
Thank's for fast support :D
I tried you script sample but get this error:
RFXtrx.Type: Rubicson id: 513 ' temperature: +28.3 deg C humidity: 47 %RH status: comfort signal: 7 battery: 9'
Python Script
Python Script
error in action "python script"
Traceback (most recent call last) (1669):
TypeError: 'NoneType' object is not callable
CommandFusion Plugin: Serial Change: 500
CommandFusion Message could not be sent: s500=0
This comes when the macro get the trigger from my temp sensor.
When i start Eventghost i get this error:
File "C:\Program Files (x86)\EventGhost\EventGhost\eg\Classes\ActionThread.py", line 33, in StartSession
pluginInfo.instance.__start__()
File "C:\Program Files (x86)\EventGhost\EventGhost\plugins\System\__init__.py", line 271, in __start__
import VistaVolEvents as vistaVolumeDll
ImportError: No module named VistaVolEvents
Error compiling script.
File "C:\Program Files (x86)\EventGhost\EventGhost\eg\Classes\ActionItem.py", line 121, in SetArguments
self.compiled = self.executable.Compile(*args)
File "C:\Program Files (x86)\EventGhost\EventGhost\plugins\EventGhost\PythonScript.py", line 71, in __init__
self.PrintTraceback()
File "C:\Program Files (x86)\EventGhost\EventGhost\plugins\EventGhost\PythonScript.py", line 97, in PrintTraceback
treeItem.PrintError("Traceback (most recent call last):")
AttributeError: 'NoneType' object has no attribute 'PrintError'
Could that be the source to the other error message?
