OdieGiblet
Post by OdieGiblet »
Thanks for this service! I had my system all perfectly configured and setup with the MCE Remote plugin. Then I changed my media center user to a basic user and bam, didn't work anymore. But this seems to be working great.
But I'm getting accidental double presses on the remote when using this plugin. It's not something I had a problem with when I was using the standard MCE Remote plugin. I see the original plugin has a "button release timeout" setting for this kind of problem. Is there something in the python scripts for this plugin that I can tweak? I didn't see anything just skimming the files.
jitterjames
Post by jitterjames »
unless you use autorepeat in your macro you should be able to hold the key down as long as you want without getting a double press (at least that's the case for me). I guess it could have something to do with your particular "flavour" of remote.
OdieGiblet
Naw, I press the Ok button on the remote and it shows up as being pressed twice in EventGhost.
jitterjames
then you probably either have a *weird* remote, or you are using the wrong version of the plugin
jitterjames
it may only happen with certain buttons if your remote sends alternate signals for the same button...
try different buttons, and other remotes that you have lying around to see if it happens consistently. I think something similar was happening to someone else if you want to search through the topic thread.
OdieGiblet
Skimmed the 20 pages on this post but didn't really find anything. So I took an hour and learned how to write a little python found what I needed to change and added a 0.3 second delay before buttons are allowed to repeat. I'll probably tweak the time to get it just right. But voila! Here's the code.
Changed this:
                            if a > 6500: #button held?
                                if self.CodeValid(self.result):
                                    #eg.PrintNotice("Sending ir code %s"%str(self.result))
                                    self.plugin.irDecoder.Decode(self.result, len(self.result))
                                self.result = []
To this:
                                    if canRepeatAgainTime < time.clock():
                                        canRepeatAgainTime = time.clock() + 0.3;
                                self.result = []
jitterjames
If these are changes that you made to the original plugin made by Stottle, perhaps there is a way to incorporate them into the plugin as an option.
I don't think most remotes require it (mine doesn't), but if others could benefit from this modification, it would be nice to have the ability to switch it on and play with the delay from the plugin settings menu.
what do you think Stottle?
djarewe
Post by djarewe »
Whaah. I'm getting crazy right here!
After dealing with for two hours, I still have to write this post.
I get managed to install the plugin and add it to EG. But when I want to add a macro, there's just no action that I can select?!
What the hell am I doing wrong??
Probably just a noob thing, but some help would be appreciated :)
Gr,
Rick
PS: I installed in on a W7-machine with EG 0.3.7.r1462
stottle
Post by stottle »
There are two plugins for MCE.
One (this one) is intended to get an MCE IR Remote/Receiver to generate events in EG.
The other (here) is to allow you to control MCE (trigger MCE actions) from EG.
Are you looking for the other plugin? If not, which actions are you looking for?
Brett
jitterjames
maybe you can explain a little bit more about what you are trying to do, and what you are doing. What is working and where exactly do you get stuck. You could even post a link to a youtube video or some screen shots.
What programs or devices are you trying to control and how? what kind of remote do you have? What other plugins are you using and can you create macros for them? If you can give some details you are more likely to get some constructive help.
If you haven't already done so and you are new to event ghost you should read the short manual.
djarewe
Post by djarewe »
Okay, this is my setup right now:
[iMon PAD (RC)] ------------IR-------------> [iMon receiver (in pc)]
[STB RC] ------------------IR-------------> [Settopbox] -----Video---> [PC]
But I want to use only one remote. That's why I bought the OVU4120 with IR Blaster.
So what I like to have is this:
[iMon PAD (RC)] -------IR (Ch+)---------> [iMon receiver (in pc)]~[PC]~[OVU4120 IR Blaster] -------IR (Ch+ STB)-------> [Settopbox]
I use VLC to watch TV. (I want to intigrate this into XBMC later).
I added the iMon plugin already. As far as I know, this works. But when I want to add the MCE remote-plugin and pless "Learn", EG hangs. That's why I downloaded the plugin from the first page. I downloaded the fix-version first, but probably I am doing something wrong. It's also new to me that there are 2 different plugins. Can you tell me more about that (and maybe some instructions for installing)?
Thanx :)
Edit:
I installed the second plugin from stottle (thanx for that). I can select some actions right now, but can't find the SendProntoCode action..
Edit2: Guys, I (almost) had it working.. I somewhere found a __init__.py-file that gave me the 'power' to transmit IR signals. However, after programming 2 buttons, EG started to act weird. When learning a signal, EG receives and displays the IR code and crashes. Had this a few times (also after rebooting).. I almost had it! :cry:
ctran503
Post by ctran503 »
THANK YOU VERY MUCH!!! I love this service plug-in you've made. Now I can use EG with XBMC as a "standard" user account!
THANK YOU!
Krazz
Post by Krazz »
Hi Stottle and thank you for the plugin.
I used to run Win XP before and everything worked like a charm with the original MCE-plugin, but now I installer Windows 7 32-bit and had to find other solutions. Unfortunately it's not working out like I hoped.
My setup is built from my Philips Pronto remote (TSU-9600) which sends commands over WiFi (TCP/IP) to EventGhost on my HTPC. EventGhost then blasts (I'm using the MCE USB receiver/blaster) the commands needed for my equipment (TV, receiver, and so on).
When I use the "Test IR Transmit capability" tester the IR-emitters on my equipment is blinking which means that everything is hooked up correctly.
Then when I move on and add the "Transmit IR" and my Pronto code nothing happens with the IR-emitters.
The Pronto code for increasing the volume on my receiver is the following:
FF AB 53 8C 1E 8C 0A 8B 1F 8C 09 8C 09 8C 1E 8C 09 8C 1E 8C 09 8C 1F 8B 0A 8B 1F 8C 1E 8C 09 8C 1E 8C 09 8C 09 8C 1F 8B 0A 8B 1F 8B 0A 8C 09 8C 09 8C 09 8C 1E 8C 0A 8B 1F 8B 0A 8B 1F 8B 1F 8C 1E 8C 1E 8C 7F 7F 7F 7B
The error I get in the log is the following:
   Error in Action: "Microsoft MCE Remote - Vista/Win7: Transmit IR: FF AB 53 8C 1E 8C 0A 8B 1F 8C 09 8C 09 8C 1E 8C 09 8C 1E 8C 09 8C 1F 8B 0A 8B 1F 8C 1E 8C 09 8C 1E 8C 09 8C 09 8C 1F 8B 0A 8B 1F 8B 0A 8C 09 8C 09 8C 09 8C 1E 8C 0A 8B 1F 8B 0A 8B 1F 8B 1F 8C 1E 8C 1E 8C 7F 7F 7F 7B"
   Traceback (most recent call last) (1462):
     File "C:\Program Files\EventGhost\eg\Classes\ActionBase.py", line 168, in CallWrapper
     File "C:\Program Files\EventGhost\plugins\MceRemote_Vista\__init__.py", line 75, in __call__
     File "C:\Program Files\EventGhost\plugins\MceRemote_Vista\pronto.py", line 246, in Pronto2MceTimings
   Exception: Don't have a decoder for pronto format FF
Do you know what the problem is?
stottle
Post by stottle »
The problem is that what you provided doesn't look like a pronto code. Take a look here. Besides 0000, the encoder can handle 6000/6001 and a few others (I'd have to go back and look at the code to see). It looks like what you have might be timings without the preamble, but I would expect the last timing to be a long off pulse, which I don't see.
Where'd you get the code?
Brett
Krazz
Post by Krazz »
The codes come from ProntoEdit Professional which is the editor used to program the Pronto remotes. The Pronto remote has the ability to learn IR-signals so this volume code I used previously is a code I learned with my Pronto into ProntoEdit, then copied into EventGhost back when I used WinXP and it has been working there for about two years now.
I will look at your link in a few hours to see what is going on.
How come my codes used to work in the original MCE plugin though?
*** EDIT ***
I just remembered that this is not how I got these codes. I think I got them by learning them into EG using the USB-UIRT (that I also have but don't use). But I'm not even sure about that any longer. One thing I AM sure of though, is that these codes worked with the original MCE plugin.
Either way, I opened up the ProntoEdit Professional where I store the IR-codes, and low and behold, they look like this:
0000 0067 0000 0022 0156 00AA 0016 003F 0016 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 0015 0016 003F 0016 0015 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 0015 0016 0015 0016 0015 0016 003F 0016 0015 0016 003F 0016 0015 0016 003F 0016 003F 0016 003F 0016 003F 0016 03FD
And what's ever better is that they work with your plugin. In other words, I screwed up. ;)
