vuego
Post by vuego »
Walter, would it be possible to make SunTracker allow more than 60 minutes of weather compensation? I have it set to 60 but sometimes wish I could use more. Thanks :idea:
Saxtus
Post by Saxtus »
I think I got it, I'll try and see how it goes.
BTW: Yay! It's snowing!!!
08:38:02   Yahoo!Weather condition not in list: Light Snow
Really? Possible in Greece???
flopp
Post by flopp »
krambriw wrote:
I get "URL Error" every 2 minutes.
It might be that your location settings are incorrect...
I tried to choose Lund in the list for Sweden, but i get URL Error anyway.
I have changes the LAT and LONG, can that be the problem?
krambriw wrote:
If i want to power on when sunset is and turn off when sunrise is, power on during whole night, how do I set it up then.
Try to set '1100' on all days like below
Thanks, i will try
flopp
Post by flopp »
flopp wrote:
krambriw wrote:
flopp wrote:I get "URL Error" every 2 minutes.
I had a very old version of suntraker, now i have updated to 1.4.5.
Now i dont get any errors
Saxtus
Post by Saxtus »
krambriw wrote:Really? Possible in Greece???
Yep, although usually doesn't snow before February, it did this morning!
In fact somebody shot a video of it and uploaded it on YouTube an hour ago! http://youtu.be/MVBjYARuyck
Aside that, I thought you should know about that state missing from your list.
Actually, I have it already (snow is common here)
The idea with the separate list is to allow you to make local adaptation without editing inside the plugin itself :wink:
Saxtus
Post by Saxtus »
I think I understood how it works now, so, time for new idea about the
"Check if time now is inside calculated virtual range including a weather compensated offset" function! :)
I've noticed that the offset is having the same number sign on both start and end period.
I was wondering if there can be a checkbox to make it have mirroring effect.
So, right now if I set:
Start = Sunrise
End = Sunset
Offset = -60
Then I get True, 60 minutes after sunrise
and False, 60 minutes after sunset.
With that option, I want to have the opposite effect with the same settings as above:
and False, 60 minutes before sunset
i.e. offset would have negative effect at the end of the period
(same should apply for weather compensation).
So, what you think about it?
Is it something that people can find useful? (apart from me of course that I am suggesting it)
User1306
Post by User1306 »
Quick question and apologies if its been asked before
Would it be possible to have the sunTracker trigger an event if it was Couldy, Raining, or Clear for example.
I think it's possible to do it though an Python script but my knowledge is very basic to none.
Would it be possible to have a quick example of such script
Really appreciate it thanks
Saxtus
Post by Saxtus »
Um, I am going to hijack some code from SunTracker plugin, as I am doing my baby steps in Python to help you (I take no responsibility if universe blows up if you read below this line!)
  • Create a new macro and add an event named "Main.Weather Condition:"
  • Add in your macro a Python Script action and paste the following:
    weather_conditions_that_will_trigger = [
        "Fair",
        "Clear",
        "Sunny",
        "Mostly Sunny",
        "Partly Sunny"
    currCondition = str(eg.event.payload)
    if  currCondition in weather_conditions_that_will_trigger:
        eg.TriggerEvent('My happy trigger')
  • Edit the script as it suits you
I tend to agree, attached is a version that should work the proposed way
BestR
(172.57 KiB) Downloaded 302 times
User1306
Post by User1306 »
Amazing, thank you very much :)
Saxtus
Post by Saxtus »
Yep, he is great!!! :D
So I have released this version now with the accumulated changes(see the first post).
PLEASE NOTE: Always take a copy of your local weather_conditions.py file before you upgrade if you have made any modifications to it and copy it back afterwards.
vuego
Post by vuego »
krambriw wrote:- Changed settings to allow 120 minutes instead of 60 for weather compensation settings.
Thanks :D
