PushBullet plugin (Pako)
skribb
Re: PushBullet plugin (Pako)
Post by skribb »
Does this work for sending files/text over local Wifi / Pushbullet Portal?
thanks :D
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
skribb wrote:Does this work for sending files/text over local Wifi / Pushbullet Portal?
No, Pushbullet Portal is not supported by this plugin. Portal has no public API, so it's not possible yet.
skribb
Post by skribb »
Oh I see, thanks for the info Pako :D
Automation is life.
Win7 64bit
EG: v0.5.0-rc4
dacari
Post by dacari »
My pushbullet in EG has stopped working..Am I the only one? getting this error:
20:23:05 Traceback (most recent call last) (1722):
20:23:05 File "C:\Program Files\EventGhost\eg\Classes\ActionBase.py", line 170, in CallWrapper
20:23:05 return self(*args)
20:23:05 File "C:\Program Files\EventGhost\plugins\PushBullet\__init__.py", line 4806, in __call__
20:23:05 iden = eg.ParseString(iden)
20:23:05 File "C:\Program Files\EventGhost\eg\Utils.py", line 206, in ParseString
20:23:05 res = eval(word, {}, eg.globals.__dict__)
20:23:05 File "<string>", line 1, in <module>
20:23:05 TypeError: 'NoneType' object is unsubscriptable
I'm sorry, but I do not know how to help. For me, everything is normal.
It is possible that I do not use any of the features.
Anyway, without more information (eg. the configuration file, or at least part of) it is not possible to help.
nikeb
Post by nikeb »
Hi Pako
I m experiencing the same problem Dacari have.
Every 20/30 seconds seems i have this error:
09:11:18 PushBullet.InternetConnection.Restored
09:11:19 PushBullet: WebSocket error: Handshake status 500
09:11:19 PushBullet.WebSocketClosed
And repeat.
Maybe some API are changed, i don't know (can't find anything on their website).
I just update the plugin (i was using an old 0.2.15 version) but nothin changes.
Do i need to give you some config files? just tell me what you need.
nikeb wrote:I m experiencing the same problem Dacari have.
This is a completely different case.
This is probably a problem with the connection.
How did you connected?
You have the opportunity to try some other connection to the Internet?
nikeb
Post by nikeb »
the PC is connecting with the same network i have since 3 years and i didn't change anything.
I also should tell you that the computer is connected to the internet and every web service works perfectly.
Good then.
You have installed Pushbullet desktop application and / or Chrome extension?
They operate normally (sending and receiving)?
Issues with Chrome Extension
Server issue under investigation. We will have this fixed asap. Sorry for the trouble!
It is interesting how the problem manifests itself:
Today I was working until 15:45 (it is 14:45 UTC).
From morning until that time, Pushbullet functioned normally.
When I arrived home, the same problem was also apparent to me.
dacari
Post by dacari »
Thanks for the feedback. Let me know if a fix comes up.
For me, it's all okay again.
nikeb
Post by nikeb »
It solved my problem too.
dacari
Post by dacari »
Still getting this error...any help would be appreciated greatly.
dacari wrote:Still getting this error...any help would be appreciated greatly.
Pako wrote:I'm sorry, but I do not know how to help. For me, everything is normal.
shaggy79
Post by shaggy79 »
Hi there, 8)
I need some help with setting this up please.....
I have:
  • Created a Google account.
    Installed PushBullet on my PC (Windows 7).
    Installed PushBullet on my phone (Android).I just rebooted my PC and got this error message in EG.... :!: :?: :!:
    • Exception in thread Thread-7:
      Signed into both devices with new Google account.
      Inserted API key into EG PushBullet plugin.
    But I cant see any of my devices through EG plugin :?: :(
    could someone please, please tell me what I'm missing
    :?: :oops:
    File "C:\Program Files (x86)\EventGhost\plugins\PushBullet\__init__.py", line 3575, in updateDevices
    self.getAccount()
    File "C:\Program Files (x86)\EventGhost\plugins\PushBullet\__init__.py", line 3458, in getAccount
    account, flag = self.request("GET", API + 'users/me')
    File "C:\Program Files (x86)\EventGhost\plugins\PushBullet\__init__.py", line 3418, in request
    c.perform()
    error: (35, 'schannel: next InitializeSecurityContext failed: Unknown error (0x80092013) - The revocation function was unable to check revocation because the revocation server was offline.')
Please can anyone help me with this....? :( :?: :(
