RFXtrx
Re: RFXtrx
Sorry, my mistake
When you provide such good debugging information, really helps a lot!
I am not 100 if the attached version is fully correct so please try. Also I would appreciate if you do and attach more logging events from the RFXmngr. I can then use those to simulate in the plugin to get the decoding working.
BR
BR
Re: RFXtrx
No worries, it's already very nice to help me with this termostat.
I'll try your new version and keep you informed
Re: RFXtrx
@ Walter
it's look working well !
I have recorded log with the last version of RFXmngr.
the periodicity of the signal transmission from the thermostat appears to be 05 mins 20 (with a few times, a jump at 10 mins 40)
Do you have a paypal account in order I give you a little gift to thank you for the help you give ?
- log.txt
- RFXmngr_log
- (3 KiB) Downloaded 107 times
Re: RFXtrx
@Stef
I have found some other issues and made further improvements. Could you use this version instead and see if it still works fine for you. I have tried to simulate as much as possible and it seems to be fully but you never know...
Kind regards, Walter
Re: RFXtrx
With your last version, it still works fine. I don't have no more issues. Thanks for your great work.
If you give me a paypal link, I will be very happy to thank you by a virtual beer
Stef (a happy french user !)
Re: RFXtrx
New version in the first post:
Now supporting:
- Thermostat1 Digimax
- Thermostat3 Mertik-Maxitrol G6R-H4 types
Now supporting:
Re: RFXtrx
I have a couple Aoke relays and most of them i can┬┤t send off command. it work with the remote. On command work fine.
Re: RFXtrx
Have you learned them as AOKE using a RFXtrx action? Please post a screenshot of one of your 'not working' AOKE actions
Re: RFXtrx
Yes've trained them as Aoke in RFX. At the signal always works but not off the signal. On the supplied remote, I press eg 1 = on 2 = off. It is 0402010200
Packet Type = Receiver / Transmitter Message
subtype = Transmitter Response
Sequence nbr = 2
response = ACK, data correct Transmitted
when I send off. When I set it to toggle mode i can turn on and off when i send on command.
Sequence nbr = 2
Re: RFXtrx
Have you tried with the RFXmngr program provided by RFXCOM?
Re: RFXtrx
Yes same result. The strange thing is that I have 12 relays one of them works but not the others.
Re: RFXtrx
Well, then it is not related to the EG plugin, there is a basic problem with the devices. Only advice I can give is to clear the memory completly on the device and re-learn them. Keep the learning button on the AOKE pressed for a long time to clear all learned codes
Re: RFXtrx
I have test it works fine to lern them with ARC.
Re: RFXtrx
Good to hear!
Yes, ARC worked fine for me as well but also learning them directly as AOKE worked fine for me (I also cleared all memory before starting)
- what type of AOKE do you have (I have separate single units with one relay)?
- what RFXtrx do you have (I have tested with the RFXtrx433E and latest firmware)?
- do you have latest firmware in your RFXtrx?
